It is currently Mon Sep 21, 2026 3:45 am
 Post subject: G'MIC 1.4.0.0 Released
PostPosted: Mon Sep 06, 2010 1:40 am  (#1)
http://www.flickr.com/groups/gmic/discuss/72157624869076834/
New tunnel effect.
 Post subject: Re: G'MIC 1.4.0.0 Released
PostPosted: Mon Sep 06, 2010 3:51 am  (#2)
Cool, thanks O! =)
PostPosted: Thu Sep 09, 2010 3:58 am  (#3)
actually is out 14.10
" Here is a new version of this quite recent 1.4.x.x branch of G'MIC, with the release of the 1.4.1.0 package today.
Here are the changes :
* Bug corrections :
- Corrected bug related to the display of 3d objects containing point primitives.
- Corrected bad memory access happening sometimes in command '-input'.
- Corrected typos in various error/warning messages.
* New features :
- New command '-gyroid3d' that generates a 3d gyroid mesh (http://en.wikipedia.org/wiki/Gyroid).
- New command '-texturize3d' that maps an image onto any 3d object.
- New default colormaps available for function '-map' and '-index' (8 in total) : hot, jet, cube, ...
- New command '-label_points3d', to add numbered label to all vertices of a specified 3d object.
- New available 3d objects for the GIMP plug-in : sphere and gyroid.
As you see, I follow the 'Release Early, Release Often' philosophy
(http://en.wikipedia.org/wiki/Release_ea ... ease_often)
(previous release was 4 days ago..). Let me say few words about it :
The development of G'MIC has reached a quite stable state where the main improvements from one version to another is the correction of bugs and the apparition of new custom commands. This means this will hardly introduce new bugs that could be considered as regressions compared to previous versions.
Moreover, I have designed a 'release script' that basically does all the release work automatically, including the build of binary packages, of the documentation, and the update of the web page. So, the more I use it, the more it is amortized :)
Hope you will enjoy this version :"
PostPosted: Sat Sep 11, 2010 2:46 pm  (#4)
new update :jumpclap :jumpclap :jumpclap
gmic 1.4.2.0
PostPosted: Sat Sep 11, 2010 3:21 pm  (#5)
Sheesh. Can't keep up with them. Downloaded 1.4.2.0 from http://sourceforge.net/projects/gmic/files/
So where is the gyroid feature? Doesn't show up in a search either.
Looks like I need to enter a command but what command? :puzzled
Any commands I've found give me an error message.
Found this website with commands and the gyroid command gives me an error message. Can someone tell me how to start and make it work?
http://gmic.sourceforge.net/reference.shtml
PostPosted: Sat Sep 11, 2010 4:10 pm  (#6)
O look in "rendering" there "3d object"
PostPosted: Sat Sep 11, 2010 4:19 pm  (#7)
Ah! Thanks PhotoComix. I'd never have found it.
Here are my results. Need to do some other stuff I guess to make it really 3D.
PostPosted: Sat Sep 11, 2010 4:36 pm  (#8)
No idea i had no much luck with gyroids!
PostPosted: Mon Sep 13, 2010 1:08 pm  (#9)
Great!
I finally had the chance to update this. =)
