It is currently Sat Aug 08, 2026 4:46 pm
 Post subject: [GMIC] 2 new filters : Metallic Grain and Metallic Stencils
PostPosted: Wed Oct 03, 2012 6:32 am  (#1)
Both derived from one of last Samj "Couleurs_Metalliques"
Both are very simple with very few controls
Anyway in case you prefer more controls just let me know, i may add easily if requested
Metallic Grain
Add a metallic grain,adapt for pictorial or special effect to the image
Basically run a preset of the new Samj metallic filter and merge the result with the original in softlight mode
A possible effect
[G'MIC] Couleurs Metalliques ; -Couleurs_Metalliques 1,1,19.7952,0,0,0,7.37201,11,3.95904,20,1,0,0,1,1.91126,10.2389,1,0,0 by PhotoComiX, on Flickr
ORIGINAL
Pasted Layer by PhotoComiX, on Flickr
METALLIC STENCILS
Even if has a really simple interface it offers 3 very different modes
Screenshot - 10_3_2012 , 1_01_15 PM by PhotoComiX, on Flickr
1 Darken
darken only by PhotoComiX, on Flickr
2 Lighten
LylejkLS-lightenonly-SamjMC by PhotoComiX, on Flickr
3 Soft Light
LylejkLS-hl-samjCL by PhotoComiX, on Flickr
i want keep really simple but maybe for this last some additional controls for the stencil part may be useful...
in case leave feedback
Another example
Original
Barrel organist Paris by Arend Vermazeren, on Flickr
Darken
Darken only 100.0_1 by PhotoComiX, on Flickr
Lighten
Lighten only 100.0_1 by PhotoComiX, on Flickr
Soft light
Softlight 100.0_1 by PhotoComiX, on Flickr
 Post subject: Re: [GMIC] 2 new filters : Metallic Grain and Metallic Stencils
PostPosted: Wed Oct 03, 2012 3:08 pm  (#2)
photo comix: cool effects, i will have to try them on something!
PostPosted: Fri Oct 05, 2012 6:42 am  (#3)
After a bit of testing i decided to radically modify o Metallic Stencil (it will have a new name too ) the differences will be :
1)option to chose between 5 "Metallic type":
To allow chose between 5 different presets (presets for Samj "Metallic Colors" filter used here as component )
2) full controls for "Lylejk Pencils" module:
restored full manual controls
3) a new optional "plush painting" effect
That looks more or less as
another option should be something as
and so with a "plush" effect
coming soon
