It is currently Sun Aug 09, 2026 10:45 am
 Post subject: G-mic plug in on a public computer (school)
PostPosted: Thu Oct 18, 2012 12:25 pm  (#1)
GIMP Version: 2.8.2
Operating System: Windows
OS Version: 7 - 32 bit
GIMP Experience: Basic Level
List any relevant plug-ins or scripts:
G-mic
I have Gimp 2.8 on my teacher machine. Yesterday, I installed g-mic on to it and had no problem with it as I am a power user on this machine. However, When I install it on the student machines, I can see the filter when I am logged in, but not when a student is. I've tried installing it to the public folder. Tried using edit-preferences-folders and redirecting, but no luck. Any suggestions?
 Post subject: Re: G-mic plug in on a public computer (school)
PostPosted: Thu Oct 18, 2012 12:46 pm  (#2)
Here is the youtube tutorial I am using as the basis for the activity.
http://www.youtube.com/watch?v=KKQXHQzV ... re=related
It only uses g-mic for the first 35 seconds. If I could accomplish this without g-mic, that is another option.
Thanks
PostPosted: Thu Oct 18, 2012 1:31 pm  (#3)
There should be a solution for that. Something with Admin permissions, I guess.
But if it's a time-sensitive matter, as a temporary workaround, you can install portable GIMP 2.8 into public folder on your master-PC and copy there all 3rd party scripts and plugins (including gmic) you want your students to work with.
Another option is to use online GMIC.
PostPosted: Thu Oct 18, 2012 4:15 pm  (#4)
Thanks, I've referred the problem to my tech dept. They played with it for about an hour with no luck. I didn't know about the gmic online. That will work for the time being. Still taking suggestions though. :mrgreen:
PostPosted: Thu Oct 18, 2012 4:26 pm  (#5)
Online version of GMIC is here http://gmicol.greyc.fr/
discussions here http://www.gimpchat.com/viewtopic.php?f ... hilit=gmic
portable GIMP (GIMP2.8.2 PC-Lab Win 32-&64-bit) http://sourceforge.net/projects/gimp-packagers/files/
PostPosted: Thu Oct 18, 2012 5:10 pm  (#6)
Are these network installs or local?
Have you tried putting GMIC in,
~\GIMP 2\lib\gimp\2.0\plug-ins
rather than,
~[user]\.gimp-2.x\plug-ins
PostPosted: Fri Oct 19, 2012 12:58 pm  (#7)
They were local installs. Thought about that folder, would I copy the exe and dll's into that folder. No school today, so will have to wait until Monday.
PostPosted: Fri Oct 19, 2012 6:34 pm  (#8)
Don't copy them, move them. Both plugin folders are pretty much the same.
When Gimp loads it will look for, GIMP 2\lib\gimp\2.0\plug-ins
and then, [user]\.gimp-2.x\plug-ins
I believe the problem is when your logged in your using, [YOUR-user]\.gimp-2.x\plug-ins folder.
When the student is logged in Gimp doesn't see [YOUR-user] it loads [Student-User] folder.
If you put the plugin at, GIMP 2\lib\gimp\2.0\plug-ins, it will be available for all users.
