It is currently Wed Nov 25, 2026 5:10 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Create a colorful watercolor portrait Using GIMP+G`MIC
PostPosted: Sat Jan 12, 2013 1:29 pm  (#1)
Hey There!
I would post my new tutorial how to craet
a nice looking watercolor effect using G´MIC filters:
Hope you like it!
I was working on these techniques for a long time to get realistic results.
G`MIC is really helpful and i love this plugin! :)
 Post subject: Re: Create a colorful watercolor portrait Using GIMP+G`MIC
PostPosted: Sat Jan 12, 2013 1:55 pm  (#2)
Maybe you could not embed the video but for sure you may post the youtube page link, and i believe even the video link
that link you tried to post doesn't work
A pity because from the example your tut seems interesting
Could you try again, don't worry about embed the video if any problem just write the page link
(or the video link and then some mods could take care to embed it, if the link is correct ,again that one you posted seems wrong)
PostPosted: Sun Jan 13, 2013 5:03 am  (#3)
No, sorry it doesnt work.
I edit this thread later... ;)
Here is a screenshot.
The tutorial show you how you can create a nice looking watercolor effect using G`MIC.
Filters: Segmentation, Egde.
The handmade parts comes from custom brushes.
PostPosted: Sun Jan 13, 2013 5:07 am  (#4)
How about this:
It really needs to be watched at 720p in full screen to see the details of what's going on.
Gareth Kitchener
Bedfordshire, England
PostPosted: Sun Jan 13, 2013 11:09 am  (#5)
I hope I can do this, I really like the looks of the result.
I would really like this as a written tutorial or with spoken instructions in the vid.
PostPosted: Sun Jan 13, 2013 12:03 pm  (#6)
Really nice I will have to look at this tutorial. Thank you for doing it. :)
PostPosted: Sun Jan 13, 2013 12:04 pm  (#7)
Thanks Hatter for posting it!
@2-ton: well, english is not my native language (it is german), so i decide to give only text instructions.
But i will give it a try next time... :)
PostPosted: Sun Jan 13, 2013 12:10 pm  (#8)
I am trying to follow, and it's well done, it's just that I have trouble trying to flip back and forth from the video to gimp...my gmic keeps on top and gets in the way and the video keeps going small every time I switch, it's a juggling act, lol. I have just managed to get to the segmentation part...long way to go! I might be able to finish tomorrow night but now I must go get some real work done!!
PostPosted: Sun Jan 13, 2013 3:01 pm  (#9)
Very nice!
PostPosted: Sun Jan 13, 2013 3:40 pm  (#10)
Bonjour,
Thank you for the video tutorial. It helped me to create a filter. Thank you again :tyspin
PostPosted: Mon Jan 28, 2013 10:38 am  (#11)
I am trying to work on this tutorial...but I have a small screen and even when I run it full screen, much of the text is blurred and I am having a lot of trouble figuring out what to do. Is there a list of the filters in order used and where to find them anywhere, or could one be made? Also the layer modes, I have to guess by position, but don't know if my gimp is ordered exactly like the one on youtube. Also, are watercolor brushes necessary or will splatter brushes work as well on the part where you add the grey splotches?
PostPosted: Mon Jan 28, 2013 10:55 am  (#12)
This is so going on my to-do list. I'll post results if I can get it to work.
PostPosted: Mon Jan 28, 2013 11:03 am  (#13)
My half-done results are pretty good, so I am anxious to learn how to finish it!
PostPosted: Mon Jan 28, 2013 11:51 am  (#14)
Excellent Chris!! Great job! I love that tutorial! Thx very much for sharing! Subscribed.
Thx for sharing :tyspin
bbbbbbbbbbbImage
PostPosted: Mon Jan 28, 2013 12:06 pm  (#15)
@2-ton, i use these filters:
1 Enhancement > Smoothing (bilateral)
2. Contours > Segmentation
3. Contours > Edges (layer mode: divide)
4. Then use a layer mask and paint with these brushes:
http://chrisdesign.deviantart.com/art/w ... -326284761
5. Add a fin art paper texture or simply use G`MIC Patterns > Paper texture
PostPosted: Mon Jan 28, 2013 9:50 pm  (#16)
Thanks, Chris, that helps a lot! I will now be anxious to finish my try on my next day off!
PostPosted: Tue Jan 29, 2013 1:38 am  (#17)
I am very pleased with this technique. Three thumbs up.
PostPosted: Tue Jan 29, 2013 11:49 pm  (#18)
very good result, ek22! It is a really good technique. Once I learn how to do it well, then I can use samj's filter much better.
PostPosted: Wed Jan 30, 2013 6:11 am  (#19)
Chris F wrote:
Hey There!
Hope you like it!
WOW! what a great video...Very nice Chris...I fixed you link so you could open it.
PostPosted: Thu Feb 07, 2013 5:34 pm  (#20)
Whew, I finally finished this. It was quite difficult to follow on my little monitor, (these old eyes are just about ready to fall out) but it's an excellent tutorial! I see that using a dark photo does not work as well as a lighter one, and the hair looks odd because I left too much showing, but now I think I can follow along fairly easily next time. I do think it works much better on a higher resolution pic, too. Especially the part where you make the white lines.
