If you use my customized Gimp build (or that from Samj) you will found all gmic definition files stored internally , at soon you open the main gimp folder inside the "gmic_filters " subfolder
That also to allow to use all additional filters even if gimp is used as portable app
But i didn't updated yet the last version to include very last gmic release in case you should do by yourself
If you do remember that you should at least once refresh the filters (or if you could not connect from that computer , download the definition files from something else and copy there. )
For the standard GIMP buildgaragecoder wrote:
You shouldn't have to rename or merge any files, just put all the individual filter (.gmic) files in the correct folder and it should be happy.
On windows 7 it's in C:\Users\yourloginname\AppData\Roaming
Correct ! that for 7 and Vista
garagecoder wrote:
so I'm assuming for windows xp it will be:
C:\Documents and Settings\yourloginname\Application Data\Roaming or something similar
First guess close but wrong, if i remember well (my xp desktop is dead
so i can't check but i almost sure) in xp the gmic definition files are stored in
(so not in Roaming ), are not grouped in a folder , just files there, and i am not sure is as default those files are visible or seen by Windows as "System Files" to be hidden
The first thing i do when i get a new computer is to impose visualization of all system and hidden files, and to NOT hide extension names that alas is the stupid default
So if there you can't see the files you may try to enter in search > option for folders and there unmark the option to hide system files (again not sure if is needed for gmic files, but i suggest to do anyway, as to unmark the option to hide extension names for the most commune files the dumb default create only problem and headaches during search )
