It is currently Mon Aug 10, 2026 4:14 am
 Post subject: filter "compression blur" (garagecoder test series)
PostPosted: Sun Jan 27, 2013 3:30 pm  (#1)
Hi GC, walking through the various g'mic functions i made some tests on your test-function "compression blur" and i'm asking whether it would be possible and reasonable in future updates extending the upper value of the parameters (now 3 for both) to a bigger value (10?). The reason is that i did a simple test with a picture with big jpeg "squares" so that the value of 3 for the grid was insufficient to remove them appropriately; so i decided to downsize the image from 2000px to 500px width, then rerun the function, then up-size back to 2000 and jpeg squares were removed. I'd like to hear your opinion on that, as well as other experiences from other users, thanks
 Post subject: Re: filter "compression blur" (garagecoder test series)
PostPosted: Sun Jan 27, 2013 4:39 pm  (#2)
Hi there, I'm surprised somebody is using it - I was actually considering removing it (it was the first gmic filter I wrote when I knew very little about the subject) but perhaps not now! The max values could be increased to perhaps 4 or 5, much more than that would only make sense on an image of immense size (because at a certain point the grid covers so much of the image that you are just smoothing the whole image). I will have a look back at the code when I redo my filters for the blend update and see what is worth doing, which will be very soon.
In the mean time, I suggest you try playing around with Enhancement > Smooth [anisotropic] since that's the function it's based on and will smooth the whole image (but with edge preservation). Also resizing an image performs a certain amount of smoothing as well due to bicubic filtering but in general results in loss of detail.
PostPosted: Mon Jan 28, 2013 3:57 am  (#3)
Hi GC,
nice to hear from you and thanks for your quick reply.
Yes, you're probably right, 5 as maximum could be good.
Your g'mic filters on jpeg enhancements are very good, so in my opinion you have to go on!
See you soon back on the subject...
PostPosted: Sat Feb 09, 2013 5:47 pm  (#4)
OK that's that it updated, there's a new option for 100% smoothing which bypasses the grid entirely. If you need more smoothing than that try either anisotropic or one of Iain Fergusson's noise reduction filters which are very good.
