It is currently Wed Aug 12, 2026 1:36 am
 Post subject: New blending modes available in G'MIC plug-in
PostPosted: Thu Feb 21, 2013 8:52 am  (#1)
Hi there,
I've followed suggestions from Pat David, and implemented some of the blending mode described in this page :
http://www.venture-ware.com/kevin/codin ... end-modes/
So, now additional blending modes : 'Linear burn', 'Add', 'Substract', 'Linear light', 'Pinglight', 'Hard mix' and 'Vivid light'
are available in the 'Layers / Blend' filter of the G'MIC plug-in for GIMP.
Just refresh your filters to get it.
Hope this can be useful.
 Post subject: Re: New blending modes available in G'MIC plug-in
PostPosted: Thu Feb 21, 2013 11:25 am  (#2)
:jumpclap :jumpclap :jumpclap :clap :clap :clap :jumpclap :jumpclap :jumpclap
PostPosted: Thu Feb 21, 2013 11:32 am  (#3)
i love you Rononours !!!!
PostPosted: Thu Feb 21, 2013 12:22 pm  (#4)
By the way, if you have other blending modes which you miss, please let me know (as well as the formula of course :)).
PostPosted: Thu Feb 21, 2013 2:08 pm  (#5)
Cool blend modes David; like the hard mix (but not the edge noise) so anisotrophic smoothed those out and created this seamless texture from it. :)
edit:
Added another seamless texture inspired by my original. Think of it as a Hot Air balloon material. Also, inadvertently deleted my original hard mix result so apologize for that. :)
PostPosted: Thu Feb 21, 2013 7:41 pm  (#6)
i found a typo: instead of Subtract, it reads Substract
also: it would be extremely helpful if a short description similar to those on the linked page, could be displayed under each layermode in G'MIC
like this:
PostPosted: Thu Feb 21, 2013 8:00 pm  (#7)
Sweet blending tools...I love how the shading brings out the highlights as well.
PostPosted: Thu Feb 21, 2013 8:58 pm  (#8)
... additional blending modes : 'Linear burn', 'Add', 'Substract', 'Linear light', 'Pinglight', 'Hard mix' and 'Vivid light'
I'm wrong or you added even more new modes ?
I see several colour modes , linear burn ... :geek
PostPosted: Fri Feb 22, 2013 3:08 am  (#9)
Thanks for noticing the typo Esper. I will correct it.
The plug-in does not allow a change of the interface in the parameter pane when one argument has been modified, so your suggestion is not possible. The best thing to do would be instead to create a new wiki page dedicated to the description of all these blending modes, with a link to it from the filter interface.
PostPosted: Fri Feb 22, 2013 8:41 am  (#10)
thats too bad
