It is currently Thu Nov 26, 2026 12:43 am
 Post subject: Where did Graphic Novel FX go?
PostPosted: Wed Apr 17, 2013 6:37 am  (#1)
Hey!
I used G'MIC quite a while ago and was really impressed by the Graphic Novel FX effect. In the newest version I installed on Linux, I couldn't find it anymore. Is it discontinued and if yes, is there a way to get an old version?
Thanks alot!
Michael
 Post subject: Re: Where did Graphic Novel FX Filter?
PostPosted: Wed Apr 17, 2013 6:40 am  (#2)
Welcome to GC. I use Windows and I'm pretty sure it's still there. Some stuff has been rearranged in later versions of G'MIC. Have you refreshed your filters lately?
 Post subject: Re: Where did Graphic Novel FX go?
PostPosted: Wed Apr 17, 2013 6:49 am  (#3)
Hey,
I have one called Graphic Novel under the Artistic heading in gmic.
PostPosted: Wed Apr 17, 2013 6:55 am  (#4)
thanks for the fast reply! I had this issue with a previous installation as well, both were fresh, the other time I installed it as a plugin file, now via the terminal using the repositories.
I searched in all the categories and can't find it, everything else seems to be there.
PostPosted: Wed Apr 17, 2013 7:03 am  (#5)
What version have you got? Have you updated the filters? I have 467 filters. See below
PostPosted: Wed Apr 17, 2013 7:09 am  (#6)
Hi telegott.
The complete list of G'MIC filters is available here :
http://gmic.sourceforge.net/gimp_filters.txt
And I can see 'Graphic Novel' in 'Artistic /'.
Not sure about your G'MIC version, as you don't have many filters (265, instead of 460+).
Maybe you should update to latest version (1.5.5.1), to be sure to get all of them. The packages provided by default with your distro are probably too old (it's the case for Debian and Ubuntu packages if you don't use a PPA).
PostPosted: Wed Apr 17, 2013 7:23 am  (#7)
Thanks for all your replies, your support is awesome!
I currently use Mint 14 which bases on Ubuntu 12, and I am using the repositories, not the packages. How can I update the filters? I just uninstalled and reinstalled G'MIC, without any effect
PostPosted: Wed Apr 17, 2013 7:30 am  (#8)
PostPosted: Wed Apr 17, 2013 7:33 am  (#9)
@telegott : Just go to : http://gmic.sourceforge.net/gimp.shtml
and download the .zip file for your architecture (either 32bits or 64bits), and copy the compressed file 'gmic_gimp' in '/usr/lib/gimp/2.0/plug-ins/' (that should replace the old one).
PostPosted: Wed Apr 17, 2013 7:37 am  (#10)
Wow, that was stupid. I apologize!
Anyway, it works! Thanks so much guys!
PostPosted: Wed Apr 17, 2013 7:39 am  (#11)
Welcome to Gimp Chat telegott!
Enjoy your time here, you'll find everyone is very helpful.
PostPosted: Wed Apr 17, 2013 8:00 am  (#12)
Ronounours wrote:
Hi telegott.
The link comes up as a blank, white page for me.
PostPosted: Wed Apr 17, 2013 8:45 am  (#13)
9:45. me too.
PostPosted: Wed Apr 17, 2013 9:11 am  (#14)
This has been fixed. Thanks.
EDIT : This randomly renders a blank page, as I'm currently working on a new version of G'MIC. Sorry about that. That will be fixed soon.
PostPosted: Thu Apr 18, 2013 3:10 am  (#15)
Hey, one last question. Gmic doesn't save the filters it found during updating, I have to update every single time I open Gimp or a new image. Is there a way around that?
PostPosted: Thu Apr 18, 2013 4:19 am  (#16)
Hi telegott, I'm using Windows and that is not a problem I have come across.
I'm sure someone will have the answer for you soon. :)
PostPosted: Thu Apr 18, 2013 9:19 am  (#17)
Strangely enough, Graphic Novel shows up in my G'MIC but doesn't show a preview and doesn't work. I've downloaded it and will try re-installing it.
PostPosted: Sun Jun 18, 2017 8:34 pm  (#18)
Try refreshing your scripts - worked for me...
PostPosted: Mon Jun 19, 2017 3:41 pm  (#19)
This is a great filter...
PostPosted: Tue Jun 20, 2017 12:31 am  (#20)
Brilliant for turning photographs into pictures for books.
However mine is just called 'graphic novel' - not 'graphic novel FX'
Is FX a Linux thing?
