It is currently Wed Aug 12, 2026 1:35 pm
 Post subject: GMIC 1-5-6-0 in gimp 2-6-12[Solved]
PostPosted: Tue Jun 18, 2013 9:23 pm  (#1)
I cannot get gmic 1-5-6-0 to run on my gimp 2-6-12, sourceforge is down so I cannot access files from there so if anyone has gmic 1-5-6-0 working on 2-6 could they let me know and attach the files they used
 Post subject: Re: GMIC 1-5-6-0 in gimp 2-6-12
PostPosted: Wed Jun 19, 2013 5:49 am  (#2)
I've only just downloaded this version - I'll try it in 2.6.11 tonight. Which files do you need?
PostPosted: Wed Jun 19, 2013 7:24 am  (#3)
The same version i use in Gimp-2.8.4 works for me in Gimp-2.6.11 Graechan.
PostPosted: Wed Jun 19, 2013 7:22 pm  (#4)
Rod I am having difficulty with 1-5-6-0 I get nothing from any of the filters so could you attach the files you used
PostPosted: Thu Jun 20, 2013 1:38 am  (#5)
I found the problem it was corrupted files in my App Data folder now everything 'honky-dorry' :yes
I thought I was going crazy crazier there for a moment thank you Rod for displaying it should work :tyspin
