It is currently Wed Aug 12, 2026 12:49 pm
 Post subject: [Solved] 64bit G'MIC install issue
PostPosted: Wed Jun 26, 2013 11:52 pm  (#1)
I tried to install the G'MIC but the 64bit install seems to be broken.
Ran the setup program and had some issues.
First it asks for libgcc_s_sjlj-1.dll, then after downloading that and putting it into the install directory,
I get an application Error, "The application was unable to start correctly (0x000007b)"
Can someone point out a solution for me?
Kurt
 Post subject: Re: 64bit G'MIC install issue
PostPosted: Thu Jun 27, 2013 12:02 am  (#2)
Kurt
OS & Gimp versions?
Try a search for, libgcc_s_sjlj-1.dll you only need one copy in,
C:\Program Files\GIMP 2\bin\libgcc_s_sjlj-1.dll
If you find a duplicate in [Users]\Odin\.gimp-2.8 folder rename it to,
libgcc_s_sjlj-1.dll.old.
Restart, Gimp.
PostPosted: Thu Jun 27, 2013 12:18 am  (#3)
Odinbc wrote:
OS & Gimp versions?
Restart, Gimp.
Sorry, Win 8 Pro, 64bit
Gimp 2.8.4
Does the G'MIC setup folder need to be somewhere specific?
PostPosted: Thu Jun 27, 2013 1:28 am  (#4)
If you are using the Installer to install Gmic then the installer can be left in your 'download folder' do not leave it in your Gimp
I always download the files in the zip from Sourceforge as that way I know what files I am installing, and to where
PostPosted: Thu Jun 27, 2013 2:00 am  (#5)
Check my G'MIC install.
Here's a list of the files in the G'MIC zip.
C:\Users\Odin\.gimp-2.8\plug-ins\
_gmic (folder)
gmic.exe
gmic_gimp.exe
jpeg62.dll
libfftw3-3.dll
libgcc_s_dw2-1.dll
libpng3.dll
libpthread-2.dll
libstdc++-6.dll
zlib1.dll
 Post subject: Re: [Solved] 64bit G'MIC install issue
PostPosted: Thu Jun 27, 2013 2:04 am  (#6)
Well this will teach me to try to do stuff while half tired and hopped up on pain killers.
User Error on this one, I was trying to 'install' the zip version :(
I was trying the run the gmic_gimp.exe to install this plugin, instead of just unzipping the file to the users gimp plugin folder.
Thanks to you guys for getting me to see what I was doing wrong.
Kurt
