It is currently Wed Aug 12, 2026 5:56 pm
 Post subject: 2 new GMIC Filters : Photocomix Graphic Boost I and II
PostPosted: Tue Nov 30, 2010 11:47 am  (#1)
Did it ! :yes
They both work...apparently as they should
you may already know my first http://www.flickr.com/groups/gmic/discu ... 372068491/
this ,brand new is the second, same pourpose (Graphicize your photos and optionally give them a painted look ) but different effects
Graphic Boost 2 by PhotoComiX, on Flickr
LAST Test (for Last Filter: PhotoComix Graphic Boost 2)
ORIGINAL
Meerkat at North Carolina Zoo by jimbowen0306, on Flickr
RANDOM EFFECTS
Graphic Boost 2 - test by PhotoComiX, on Flickr
 Post subject: Re: 2 new GMIC Filters : Photocomix Graphic Boost I and II
PostPosted: Tue Nov 30, 2010 12:06 pm  (#2)
I refreshed G'MIC but Boost 2 didn't get loaded. I used Boost 1 with the default on a squirrel I found here.
PostPosted: Tue Nov 30, 2010 12:21 pm  (#3)
Not sure David has loaded the second preset in, O. You have to add that to the .gmic file manually.
UPDATE: As of 12 minutes ago, David did add the second preset to G'MIC, refresh away! :)
PostPosted: Tue Nov 30, 2010 12:30 pm  (#4)
Yay!!!! Yep, it's there. PhotoComix :geek
PostPosted: Tue Nov 30, 2010 12:51 pm  (#5)
This is an image I got at stock xchg
Original
Boost II. I love the way it enhances the markings on the two okapis. (Yeah, I had to look up the plural of okapi in the dictionary.)
PostPosted: Tue Nov 30, 2010 1:01 pm  (#6)
PC:
Did you keep track of your settings as you randomly used the preset? I really like the next to last meerkat image, and have been trying to duplicate it. I love the way it highlights and lets the colors come through.
PostPosted: Tue Nov 30, 2010 1:02 pm  (#7)
O cool that work for you now ,i like the opakis
About the squirrel that sort of pixelation of the BG was a by effect of the filter or come from some other edits ?
PostPosted: Tue Nov 30, 2010 1:05 pm  (#8)
I used the default settings in Boost I on the squirrel.
The original squirrel is here.
PostPosted: Tue Nov 30, 2010 1:09 pm  (#9)
mahvin wrote:
PC:
Not really but i hope i may replicate
I was thinking to a even better way to solve, create a few basic presets (to be then finetuned by users )
there is a obstacle (filter appear in the favs, and favs can't be faved again ) but i think to have a workaround to create and share also presets, not only the filter
so stay in tune ...
PS
@O Thank i will check and maybe change default
(maybe not...is possible that are overcompressed jpg artefacts, barely visible in the original but made more visible by the filter effect )
PostPosted: Tue Nov 30, 2010 1:15 pm  (#10)
PhotoComix wrote:
PS
I think that may be over come adjusting the various sliders in the filter. I wanted to use the default settings so I could see well what it started with.
PostPosted: Tue Nov 30, 2010 1:59 pm  (#11)
Saw that David added the first preset before doing a few chores. Going to refresh G'MIC again after posting this response. Thanks again PC; now get some sleep. lol
PostPosted: Tue Nov 30, 2010 5:40 pm  (#12)
Thanks again PC; now get some sleep. lol :)
maybe later...i want finish my very first project of gmic filter ( i was blocked by some complex " if " )...and i am fascinated by still hypotetic Value Color and Luminosity mode...more i need a sort of simple Fade control as component.
Once i had some books on C, i never read them, not a single one
but i was often staring the C-books pile wandering...usually something as:
" Holy God , how is possible that is needed to read all that crap just to be able to display a "Hello World" on the screen ? I may do without C , just with black ink "
But now is much more interesting not only because Gmic language is easier, and the gmic plugin has everything else ,(i mean interface ,input/output option , preview )ready.
.but mostly because the results for me are much more worth the efforts than automatize the typing of "hello world"
(how is possible that after generations of teachers of C, C#, C+, Java, Python and so on and on...nobody come out with something more motivating as first result then a "Hello Word"? )
PostPosted: Tue Nov 30, 2010 5:59 pm  (#13)
Wonder what you think of Logo (turtle language). lol
Enjoy the play PC. :)
PostPosted: Wed Dec 01, 2010 9:08 am  (#14)
@ Oregonian @lylejk
i think that chose at best the default values is very important for the usability of a filter BUT i didn't yet take care to find the best default setting
it is on top of my to do list (new versions are coming soon )
IN the while i appreciate suggestion (as example what happened in the first O test, i mean the pixelation should happen very seldom
with good default values )
PostPosted: Wed Dec 01, 2010 9:33 am  (#15)
Very nice PC!
Thanks for sharing these great additions to G'MIC. =)
Cookies for you are in order.
My images:
Stock
Boost 1
Results - Played with pencil smoothing and set the layer merging to overlay on this one.
Boost 2
Results - This one is just default.
Awesome results PC!
Thanks again. :coolthup
PostPosted: Wed Dec 01, 2010 1:33 pm  (#16)
cool results Rod :yes
PostPosted: Thu Dec 02, 2010 12:33 am  (#17)
Sweet image results, Rod, using some sweet presets!! I take my hat off to PC! Boost and Boost II are awesome!
My Sigs = My Photos
PostPosted: Thu Dec 02, 2010 9:39 am  (#18)
I love all the cool results people are getting.
That ship is great, Greg. The touch of red along with the blue and grey ... yum.
PostPosted: Thu Dec 02, 2010 1:49 pm  (#19)
Yeah that really pops out and gets your attention, nicely done Greg.
PostPosted: Mon Dec 13, 2010 12:59 pm  (#20)
This is very cool PC, thanks for making them. I arrived at an interesting image through the Graphics Boost I preset. I had saved a few fractal images I generated and ran one through the filter with default settings and G'MIC set to give a new layer output, then colorized the output layer with default, then set layer mode to Grain extract:
File comment: Graphics Boost I on fractal.
Here's the original:
Life Truth: #12
