It is currently Sun Aug 09, 2026 11:51 am
 Post subject: Emulate XnRetro and Photo B&C effects
PostPosted: Wed Jul 31, 2013 5:31 pm  (#1)
Xnretro http://www.xnview.com/en/xnretro/ (It is for windows but may work with Wine )
from the same developer of Xnview is a nice graphic toy ,
...i really just start playing with it but i believe that most of the effects may be emulated in gmic ...
This should be easier
http://www.photofiltre-studio.com/freew ... obc-en.htm ,
that works well if there is a chromatic contrast between the object and the bg ... i think gimp may do better in more difficult cases
oh and a very simple but neat animation effect ,this it is really a old utility ,never updated from 2006 but still works with 7, at least in compatibility mode , ...very simple but i always found its reflection effects really neat ...
And also this should be possible , there are already similar effect in gmic but not really equivalent
No i am not thinking to try to code any of those soon, i 'm too busy trying to update my old filters
But are cool effects ... :roll:
 Post subject: Re: Emulate XnRetro and Photo B&C effects
PostPosted: Wed Jul 31, 2013 8:36 pm  (#2)
Thanks for the links PC. :)
Normally i just use the Tintii 8BF filter with PSPI, but it isn't free for Windows users like your options. :)
The Linux version of the Tintii software is free though.
http://www.indii.org/software/tintii/download
PostPosted: Wed Jul 31, 2013 11:04 pm  (#3)
There is a Linux version of Xnretro.
