It is currently Mon Aug 10, 2026 4:49 am
 Post subject: New G'MIC Filter (test) : Toile Araignée - Cobweb
PostPosted: Fri Dec 13, 2013 6:13 pm  (#1)
Bonjour,
Here is a small script that gives images in 2 colors.
(It is an attempt to create textures)
Filters > G'MIC > Testing > 004 > Toile Araignée - Cobweb
Image - Origine : http://www.fontplay.com/freephotos/4thf ... 706-13.jpg
Edit 20131214 : New version "GMIC_Filters-004_b.zip"
Edit 20131215 : New version "GMIC_Filters-004-c.zip"
GMIC_Filters-004-c.zip [6.98 KiB]
Downloaded 133 times
 Post subject: Re: New G'MIC Filter (test) : Toile Araignée - Cobweb
PostPosted: Fri Dec 13, 2013 7:23 pm  (#2)
Thought I'd give Wilbur a bit of a pasting
curious as to why you don't add the filters under Testing>Samj though
PostPosted: Fri Dec 13, 2013 7:40 pm  (#3)
Looks like Wilbur got caught in a Lobster net Graechan
PostPosted: Sat Dec 14, 2013 4:10 am  (#4)
Thanks Sam. As soon as my Mycelium render in color is complete i will give this a try. I tried to run both G'MIC and Mycelium at the same time but G'MIC crashes. :(
PostPosted: Sat Dec 14, 2013 4:15 am  (#5)
G'MIC crashes ? What does it say ?
PostPosted: Sat Dec 14, 2013 4:24 am  (#6)
AppName: gmic_gimp.exe    AppVer: 0.0.0.0    ModName: gmic_gimp.exe
ModVer: 0.0.0.0    Offset: 000a0ab0
I think it has a lot to do with me pushing my500 MB of RAM too it's limits David. :lol
PostPosted: Sat Dec 14, 2013 5:49 am  (#7)
@ David - Actually i had to re download the new installer from your website David and re install G'MIC over Sams version. For some reason it wouldn't work anymore. No problems now.
@ Sam - i can't find the filters in Filters>G'MIC as i moved my G'MIC to the image window via the pluginrc file. I assumed it would create a new G'MIC menu item but it didn't. Can you add the filters to your testing/Samj list in G'MIC itself?
Found them :lol I didn't realize you meant a new "Testing" item in the filters list inside G'MIC i thought you meant Gimps menu list Filters>G'MIC :)
Silly me. I was pondering how you were able to get a G'MIC filter to open in the Gimp Filters list though. :rofl
PostPosted: Sat Dec 14, 2013 6:31 am  (#8)
My cobweb splash. :)
Neat effect Sam.
PostPosted: Sat Dec 14, 2013 7:16 am  (#9)
Bonjour,
@Graechan
My scripts are ephemeral, they die quickly.
@Rod
I'm glad you could find the correct directory to place the scripts :)
PostPosted: Sat Dec 14, 2013 10:45 am  (#10)
I added a script "Texture 002".
You can download the new version "GMIC_Filters-004_b.zip" from the first message.
Filters > G'MIC > Testing > 004 > Texture 002
Image 2 - Origine
http://mythobyfleur2lun.canalblog.com/i ... ailles.jpg
(scaling of the image > cutting > curves color > new filter Texture 002)
PostPosted: Mon Dec 30, 2013 11:33 pm  (#11)
I like it SamJ, kind of leprocy look about it though;)
