It is currently Wed Aug 12, 2026 4:54 am
 Post subject: How could I compile...
PostPosted: Sat Jan 18, 2014 8:41 pm  (#1)
How could I compile the g'mic.tar.gz file in fedora 19?.
I didn't see any instructions in the README file.
It's impossible to me install g'mic (or that g'mic works) from any gmic_version_linux64.zip.
With Debian (64) and Mint (32) I have not problems.
Thanks!.
 Post subject: Re: How could I compile...
PostPosted: Sat Jan 18, 2014 8:51 pm  (#2)
In order for GMIC to work properly, you will need to install libpng12 from the Fedora repositories.
As root, from terminal..
yum install libpng12
 Post subject: Re: How could I compile...(SOLVED)
PostPosted: Sat Jan 18, 2014 9:03 pm  (#3)
Many thanks Gnu Tux.
I tried this before using a r.p.m. package but it wouldn't be the correct one (libpng-1.5.13-7.1.x86_64).
PostPosted: Sat Jan 18, 2014 9:34 pm  (#4)
Yes. I have to remember to install that package every time I upgrade to a new version of Fedora. G'MIC requires an older version of libpng in order to work properly and it's not installed by default in Fedora Linux.
