It is currently Tue Nov 17, 2026 4:04 am
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3  Next
 Post subject: Compiling Knotter For Linux - new compiles-32 and 64 bit
PostPosted: Sat Aug 18, 2012 5:09 pm  (#1)
How do i compile software.
I downloaded knotter and want to check it out. :)
http://libregraphicsworld.org/blog/entr ... design-app
EDIT: Both 32 and 64 bit versions now compiled.Read on for further information.
 Post subject: Re: So here i am using Fedora 17 :)
PostPosted: Sat Aug 18, 2012 6:19 pm  (#2)
I also downloaded the online-installer run file but Fedora tells me there is no application to open the file?
PostPosted: Sat Aug 18, 2012 7:22 pm  (#3)
Knotter has to "Qt Framework" as a dependency. You need first install basic build tools for compiling in Fedora, then "qmake" and Qt4 development tools.
You tell me where you downloaded the .run file, so I can see how to install it.
By the way, you can try to run the file from the terminal. First make sure it is executable, or else make it executable: "chmod +x file.run"
Then run it with (if it requires root privileges): "sudo ./file.run"
PostPosted: Sat Aug 18, 2012 7:33 pm  (#4)
Thanks Yafu, you can get the run file here
http://qt-project.org/downloads
PostPosted: Sat Aug 18, 2012 7:40 pm  (#5)
This works
yum install qt-devel qt-config
now i should be able to compile the src files. ;)
PostPosted: Sat Aug 18, 2012 7:45 pm  (#6)
I thought you were referring to an installer for Knotter :mrgreen:
Great that you could find the packages for Fedora :yes
PostPosted: Sat Aug 18, 2012 9:04 pm  (#7)
I had to fix the makefile
i still get errors though. Any ideas?
[rod@rod knotter-0.4.0]$ make
g++ -c -pipe -Werror -g -Wall -W -D_REENTRANT -DVERSION=\"0.4.0\" -DQT_SVG_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/lib/qt4/mkspecs/linux-g++ -I. -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include/QtXml -I/usr/include/QtSvg -I/usr/include -Isrc/dialogs -Iinclude -Isrc/generated -Isrc/generated -o knot_curve_style.o src/graphics/knot_curve_style.cpp
src/graphics/knot_curve_style.cpp: In destructor ‘knot_curve_styler::~knot_curve_styler()’:
src/graphics/knot_curve_style.cpp:232:16: error: deleting object of abstract class type ‘knot_curve_style’ which has non-virtual destructor will cause undefined behaviour [-Werror=delete-non-virtual-dtor]
cc1plus: all warnings being treated as errors
make: *** [knot_curve_style.o] Error 1
Makefile attached
Knotter_Makefile_RD.tar.gz [3.35 KiB]
Downloaded 650 times
PostPosted: Sat Aug 18, 2012 9:29 pm  (#8)
It seems to be something wrong with the line 232 of file src/graphics/knot_curve_style.cpp.
I think it should be reported to the developer. Or maybe someone who knows programming can know how to correct that lines.
PostPosted: Sat Aug 18, 2012 9:31 pm  (#9)
I reported it at Libre graphics. :)
PostPosted: Sat Aug 18, 2012 9:59 pm  (#10)
Did you tried with the latest code from Git?
Install git from Fedora repo, and:
git clone git://git.code.sf.net/p/knotter/code knotter-code
Enter to the directory "knotter-code" (Open the terminal on that path), and try to compile.
Edit: I could compile and install from git. But when you run the program (executing "knotter" binary) it goes into what seems an infinite loop and collapses my system (64bit)
Edit again: I was able to compile the 0.4.0 version. Maybe your problem is with the version of qt devel tools? (mine is 4.8.1). Likewise I have the same problem with the git (today) version.
PostPosted: Sun Aug 19, 2012 7:28 am  (#11)
As Mattia says in the LibreGraphic, RAM problem is fixed.
Here I share the 64-bit binary:
http://www.fileswap.com/dl/6f0onqzfnt/K ... ts.7z.html
PostPosted: Sun Aug 19, 2012 11:58 am  (#12)
I am using 32 bit Linux though. :(
PostPosted: Sun Aug 19, 2012 12:15 pm  (#13)
I get this error on compile now with Fedora.
Almost there. :)
knot_window.o: In function `Knot_Window::Knot_Window(QWidget*)’:
/home/rod/src/knotter-0.4.5/src/dialogs/knot_window.cpp:36: undefined reference to `Export_Dialog::Export_Dialog(QWidget*)’
/home/rod/src/knotter-0.4.5/src/dialogs/knot_window.cpp:40: undefined reference to `Export_Dialog::set_knot_view(KnotView*)’
knot_window.o: In function `Knot_Window::export_image()’:
/home/rod/src/knotter-0.4.5/src/dialogs/knot_window.cpp:342: undefined reference to `Export_Dialog::reset_size()’
knot_window.o: In function `Export_Dialog::~Export_Dialog()’:
/home/rod/src/knotter-0.4.5/src/dialogs/export_dialog.hpp:7: undefined reference to `vtable for Export_Dialog’
collect2: error: ld returned 1 exit status
make: *** [knotter] Error 1
Its been reported to the author. :)
I am going to try the GIT clone once.
PostPosted: Sun Aug 19, 2012 12:35 pm  (#14)
Yes ... success with the git clone.
Thanks Yafu.
i will have the upload available for 32 bit Linux soon.
PostPosted: Sun Aug 19, 2012 12:51 pm  (#15)
PostPosted: Sun Aug 19, 2012 1:04 pm  (#16)
You've exported as svg?
What kind of error you get? Copy the error message here.
I've been able to export to Inkskape
PostPosted: Sun Aug 19, 2012 1:13 pm  (#17)
No i have Cairo Dock and i cant get this app or Inkscape to dock there.
I can export to SVG fine.
I did get an error and crash after doing something in the software but i cant duplicate it so i didn't report it.If it happens again i will. :)
If anyone is interested in the 32 bit binary for Fedora let me know and i will upload it otherwise i will save the room on my server.
 Post subject: Re: Compiling Knotter For Linux
PostPosted: Sun Aug 19, 2012 6:07 pm  (#18)
You are welcome to post it here, Rod. We have plenty of server space.
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Sun Aug 19, 2012 7:03 pm  (#19)
Thanks Tux i added the program to another topic. :)
PostPosted: Wed Aug 22, 2012 5:15 pm  (#20)
Yafu have you compiled 5.0 yet? :)
Are there any significant changes to the tools?
