It is currently Tue Nov 17, 2026 12:12 am
 Post subject: Re: Knotter dot to dot
PostPosted: Fri May 24, 2013 7:43 pm  (#1)
I don't have knotter on my computer. maybe some day.
PostPosted: Thu May 30, 2013 7:39 am  (#2)
Here's my effort. I've posted my whole screen so that you can see the values I used.
PostPosted: Fri May 31, 2013 6:03 am  (#3)
Erisian, you can download windows version here http://sourceforge.net/projects/knotter ... indows.zip (direct link download)
PostPosted: Fri May 31, 2013 6:04 am  (#4)
Thank you d4rkheart.
PostPosted: Sun Jun 09, 2013 5:17 pm  (#5)
A wee shout-out for Knotter 0.9 at Libre Graphics World.
PostPosted: Sun Jun 09, 2013 5:35 pm  (#6)
Thanks for the heads up odin; left a message there. :)
PostPosted: Sun Jun 09, 2013 9:46 pm  (#7)
Isn't that only made for Linux?
PostPosted: Sun Jun 09, 2013 9:50 pm  (#8)
Windows too Knotter at sourceforge.
PostPosted: Sun Apr 05, 2015 8:06 pm  (#9)
I made Erisian's knot and then discovered a setting that changed it completely. Under edges if you change the selection from Regular to Wall, you get this effect.
PostPosted: Tue Feb 14, 2023 2:54 am  (#10)
looks beautiful
