It is currently Mon Nov 16, 2026 5:35 pm
 Post subject: Animated Rain Droplet Brush
PostPosted: Wed Mar 26, 2014 4:57 pm  (#1)
I used Molly's tutorial, "Creating (water) drops with GIMP" viewtopic.php?f=23&t=10046#p131443
To make the droplets in this brush.
Thanks Molly!
Here's a preview image of what the brush can do.
You will need to set the layer mode to "Overlay" to create this effect using this brush.
Water Droplets.gih [403.69 KiB]
Downloaded 259 times
 Post subject: Re: Animated Rain Droplet Brush
PostPosted: Wed Mar 26, 2014 4:59 pm  (#2)
Thank you. That'll come in useful!
PostPosted: Wed Mar 26, 2014 5:07 pm  (#3)
Thanks, I hope that it will.
PostPosted: Wed Mar 26, 2014 5:11 pm  (#4)
Thanks Wallace.
PostPosted: Wed Mar 26, 2014 5:13 pm  (#5)
Thanks Wallace.
Thank you Molly! :mrgreen:
PostPosted: Wed Mar 26, 2014 5:44 pm  (#6)
Nice work Wallace.
PostPosted: Wed Mar 26, 2014 6:12 pm  (#7)
Nice one. Thank you!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Wed Mar 26, 2014 6:14 pm  (#8)
The Warrior wrote:
Nice work Wallace.
Thanks Warrior. :bigthup
Do you think you can give the brush a try, to see how it works for you?
Well... we'll see if it can work of you as it did for me. ;)
PostPosted: Wed Mar 26, 2014 6:43 pm  (#9)
I like it okay. I personally think a single drop into a brush would be better though. Can always change the size. I have a hard time getting "even" placement of the drops. I also tried displacement mapping, to get the drops to go with the apple contours, but wasn't very successful.
PostPosted: Wed Mar 26, 2014 6:47 pm  (#10)
Very cool Wallace! :coolthup
Thx!
bbbbbbbbbbbImage
PostPosted: Wed Mar 26, 2014 6:53 pm  (#11)
I hear you. I did make a single water-drop brush.
PostPosted: Thu Mar 27, 2014 6:42 am  (#12)
Thanks, Wallace.
PostPosted: Thu Mar 27, 2014 7:06 am  (#13)
Thank you Wallace. It'll be very useful. :tyspin
PostPosted: Thu Mar 27, 2014 9:26 am  (#14)
I like it too. Thank you, Wallace!
PostPosted: Thu Mar 27, 2014 10:23 am  (#15)
Cool, only thing missing is the highlight on the drops. :)
PostPosted: Thu Mar 27, 2014 11:08 am  (#16)
Can you suggest how I can add these "highlights" to the droplets of my animated brush?
PostPosted: Thu Mar 27, 2014 11:31 am  (#17)
One at a time Wallace with a small soft brush. :teeth
PostPosted: Thu Mar 27, 2014 12:14 pm  (#18)
It can't be done if the layer is or brush is set to overlay, it would have to be added after like Molly suggested.
PostPosted: Thu Mar 27, 2014 12:55 pm  (#19)
This is what the brush looks like and all layers have a normal mode.
You're saying that I could add more highlights to these droplets?
PostPosted: Thu Mar 27, 2014 1:10 pm  (#20)
I add a layer at the top and put the hi litres in one by one Wallace. That is the only way I know.
