It is currently Wed Nov 18, 2026 11:53 am
 Post subject: Squares and Rectangles Aimated Brush
PostPosted: Thu Jan 22, 2015 11:23 pm  (#1)
As the title says, Squares and Rectangles Animated Brush. I really don't know what this brush might be use for, but I got the idea form making a text ball/globe in this thread viewtopic.php?f=22&t=11860#p160274.
Here's a preview image that I made using this brush, enjoy.
Squares and Rectangles Animated Brush.zip [15.99 KiB]
Downloaded 271 times
 Post subject: Re: Squares and Rectangles Aimated Brush
PostPosted: Fri Jan 23, 2015 2:58 am  (#2)
So productive Wallace, and I find the brush very interesting. I'll think of something to use it. Thank you so much. :clap :bump
PostPosted: Fri Jan 23, 2015 3:43 am  (#3)
Thanks Issabella.
Unfortunately I feel that I shouldn't have included a drop shadow as part of the brush. What's done is done.
PostPosted: Fri Jan 23, 2015 5:53 am  (#4)
Hi Wallace,
The brush preview in the brush tab appears too small. Maybe you can consider increasing the preview size:
PostPosted: Fri Jan 23, 2015 6:11 am  (#5)
Thank you Wallace. I was playing with your animated brush. I like it a lot. :hi5
PostPosted: Fri Jan 23, 2015 6:14 am  (#6)
Thanks Wallace i will find a use for them somewhere. :)
PostPosted: Fri Jan 23, 2015 10:16 am  (#7)
josephbupe wrote:
Hi Wallace,
I don't understand?
Are you suggesting that I somehow have control over the brushes preview image that is displayed in your Gimp brush dialog?
PostPosted: Fri Jan 23, 2015 11:36 am  (#8)
@Wallace:
For a brush pipe, the preview image displayed in the brushes dialog is simply the FIRST image in the pipe.
Unfortunately, in your "Squares and Rectangles Animated Brush", the first image is of a very small rectangle ..hence it hardly shows up in the dialog tile. If you've still got your .xcf for this pipe you could simply move a larger image to the first position (presumably the bottom layer) or even present a composite of a largish square and a largish rectangle.
PostPosted: Fri Jan 23, 2015 11:48 am  (#9)
jontait2 wrote:
@Wallace:
Thanks Jontait2, but I'm aware of this and the brush will remain as is. Unless those that wish to change this actually do so, by opening the brush as an image and moving the layers themselves. ;)
