It is currently Wed Sep 30, 2026 12:31 am
 Post subject: animated euro brush
PostPosted: Thu May 14, 2015 12:21 pm  (#1)
on request,euro brushes
also an animated euro brush
select the animated brush,put your cursor on your image.
hold down the left mouse button,and slide your cursor over your image
the euro will appear one after the other
Euro brushes are in the zipped folder
1euro.zip [5.28 MiB]
Downloaded 297 times
 Post subject: Re: animated euro brush
PostPosted: Thu May 14, 2015 2:16 pm  (#2)
I said it as a joke, but you got it! :hehe Thank you Gimper. :tyspin :coolthup
PostPosted: Thu May 14, 2015 2:45 pm  (#3)
issabella,I know but it was stronger than myself So I made the brushes
