It is currently Tue Sep 29, 2026 9:28 pm
 Post subject: Leaf Brushes and Extra Stuff
PostPosted: Wed Nov 09, 2016 6:05 pm  (#1)
Hey, guys! I made a post earlier today asking how to fix a crash I was having with gimp. Well, thanks to you wonderful people, I got that fixed. Which means I could create these awesome brushes and share them you all! Everything you need to know about them will be in the .txt file inside the folder.
I have also attached a preview image of what these brushes can do!
File comment: Here is a glimpse of what the brushes can do!
File comment: Enjoy these brushes that took me 3 days of work to finish! :D
BK_Resources_Gimp_Brushes_Leaves_09Nov2016.zip [2.15 MiB]
Downloaded 540 times
 Post subject: Re: Leaf Brushes and Extra Stuff
PostPosted: Wed Nov 09, 2016 8:15 pm  (#2)
You really might want to check out Ofnuts Add-On Manager for all your brushes, etc. Eliminates the need to have ALL the brushes loaded and you can create brush categories.
https://sourceforge.net/projects/gimp-t ... s/scripts/
PostPosted: Wed Nov 09, 2016 8:52 pm  (#3)
Hey, yeah! I'd love to take a look at that and see if it is something I'd like. I didn't know it existed! Thanks! However there is a problem... Either the link is broken, or maybe you copied it wrong or something because when I click it, it takes me to a "Page Not Found" message.
PostPosted: Wed Nov 09, 2016 9:28 pm  (#4)
I'm not sure why Mahvin's link doesn't work,
because it basically looks the same as my link.
I do believe the link below,
should take you to the available Ofnuts' Gimp Tools at surceforge.
Of which,
if you scroll down you'll find the addonCollectionManager-3.0.py.
PostPosted: Thu Nov 10, 2016 8:15 am  (#5)
And here is a link to Ofnuts AWESOME path filters!
https://sourceforge.net/projects/gimp-p ... s/scripts/
PostPosted: Fri Nov 11, 2016 8:41 am  (#6)
Of which,
Thanks, that did the trick! It works! :D
Thanks!!! I will definitely give these all a look!
PostPosted: Fri Nov 11, 2016 10:33 pm  (#7)
Nicely done on the brush pack by the way. :D
