It is currently Wed Nov 18, 2026 2:05 pm
 Post subject: 23 Gimp Debris Brushes
PostPosted: Mon Oct 30, 2017 1:21 pm  (#1)
As previewed using the gif image below.
23
Gimp Debris Brushes
Each brush is a 900 x 900 gray-scale brush.
Also provided are the png images for each brush.
File comment: Debris Brushes
23_gimp_debris_brushes.zip [1.56 MiB]
Downloaded 569 times
File comment: Brush PNG Images
debris_png_images.zip [1.71 MiB]
Downloaded 380 times
The brush and PNG files,
are within their own compressed zip folder,
which must be extracted before the files can be utilized.
Note: PNG images contain a white background.
Brush and PNG files are free to use without limitations.
 Post subject: Re: 23 Gimp Debris Brushes
PostPosted: Mon Oct 30, 2017 3:14 pm  (#2)
Thank you so much Wallace. nice brushes. :tyspin
PostPosted: Mon Oct 30, 2017 3:57 pm  (#3)
PostPosted: Mon Oct 30, 2017 5:17 pm  (#4)
What did you use to generate them, they look so 3D! :D
PostPosted: Mon Oct 30, 2017 5:29 pm  (#5)
I didn't render them.
I got them from Graphicriver and made brushes out of them...
PostPosted: Mon Oct 30, 2017 5:34 pm  (#6)
Nicely done!! Thanks Wallace!
My Sigs = My Photos
PostPosted: Mon Oct 30, 2017 8:19 pm  (#7)
PostPosted: Tue Oct 31, 2017 4:11 am  (#8)
Excellent Wallace - thank you! I was just browsing Deviantart for brushes to rough up and splatter the "canvas" when painting, then while I was taking a break, I thought I would have a look at GC, and look what I found here!!! Thanks again.
PostPosted: Tue Oct 31, 2017 4:16 am  (#9)
Thanks again.
No problem Erisian.
I had these image resources for a while.
Only just put them together yesterday as brushes.
Enjoy!
PostPosted: Wed Nov 08, 2017 8:01 am  (#10)
Excellent brushes Wallace, thankyou so much :bigthup
PostPosted: Wed Nov 08, 2017 10:42 am  (#11)
Enjoy.
PostPosted: Wed Nov 08, 2017 1:30 pm  (#12)
Very nice brushes Wallace.
PostPosted: Wed Nov 08, 2017 1:37 pm  (#13)
