It is currently Tue Nov 10, 2026 6:27 am
 Post subject: MyPaint brushes Tone Ver.3
PostPosted: Wed Aug 07, 2019 1:01 am  (#1)
In Gimp 2.10.12, MyPaint brushes work in version 3.
So I converted a pack of "Tone" 124 brushes from version 2 to 3.
MyPaint brush location: ...\share\mypaint-data\1.0\brushes\tone
Tone V3.zip [1.61 MiB]
Downloaded 767 times
 Post subject: Re: MyPaint brushes Tone Ver.3
PostPosted: Wed Aug 07, 2019 3:14 am  (#2)
Nice collection. :bigthup
Thanks for sharing them with us.
PostPosted: Wed Aug 07, 2019 5:50 am  (#3)
Awesome! Thank you very much for these. :bigthup
PostPosted: Wed Aug 07, 2019 10:45 am  (#4)
Thank you so much MareroQ. I love them. :tyspin :coolthup
PostPosted: Wed Aug 07, 2019 3:48 pm  (#5)
The order configuration file will overwrite the existing one. Is it OK to simply copy the information from the new order file to the existing one?
PostPosted: Wed Aug 07, 2019 11:24 pm  (#6)
Hi Erisian
"Order.conf" - this is only additional information (a list that facilitates management, e.g. in case you want to remove unnecessary brushes) - You can delete, rename or combine various order.conf files.
PostPosted: Thu Aug 08, 2019 1:47 am  (#7)
Online
Looks very useful indeed. Thank you.
PostPosted: Thu Aug 08, 2019 2:53 am  (#8)
MareroQ wrote:
Hi Erisian
Thank you. I'm looking forward to trying these out.
PostPosted: Thu Aug 08, 2019 9:45 am  (#9)
Thank you, I didn't even know about My Paint brushes until now. ... more fun for me !
PostPosted: Thu Aug 08, 2019 1:29 pm  (#10)
Thank you MareroQ!
I would like to test them, but in Gimp portable samj, should I put them in:
D: \ Gimp-2.10.12_Port_20190615 \ Preferences \ brushes ????
PostPosted: Thu Aug 08, 2019 3:11 pm  (#11)
level_0 wrote:
Thank you MareroQ!
The mypaint brushes are a special case,
Regular Gimp / Portable Gimp , the first stop is always
Edit -> Preferences -> Folders -> MyPaint Brushes. Then have a look at the paths.
You can make a folder C:\Users\your-name\.mypaint\brushes and put the "tone" folder there but since it is a "portable" gimp put the folder in the first location.
Start Gimp and a good idea is open the mypaint brushes dock.
Windows -> Dockable Dialogues -> MyPaint Brushes Use the filter at the top of the dock to filter just the "tone" set.
PostPosted: Fri Aug 09, 2019 1:24 am  (#12)
:wvy
rich2005, I blame myself for not having thought of Edit / Preferences /FoldersImage
Thanks also for the screenshot and the advice :)
PostPosted: Fri Aug 09, 2019 4:09 am  (#13)
rich2005
In the "Tone V3" folder, there is an "order.conf" file (3 KB)
Should I put it too? And if "yes", there is already one in D: \ Gimp-2.10.12_Port_20190615 \ share \ mypaint-data \ 1.0 \ brushes (4 KB)
PostPosted: Fri Aug 09, 2019 4:19 am  (#14)
level_0 wrote:
rich2005
The order.conf file isn't too important. See here http://gimpchat.com/viewtopic.php?f=12&t=17631#p241843
PostPosted: Fri Aug 09, 2019 4:30 am  (#15)
Erisian, I had zapped that (too stressed ...) :tyspin
PostPosted: Fri May 17, 2024 10:48 pm  (#16)
thank you so so so so much!!!!! :pengy
