It is currently Tue Nov 10, 2026 6:51 am
 Post subject: Brush Resource For Colorful Tubes
PostPosted: Sat Jun 06, 2020 7:44 pm  (#1)
Here are the results of using this xcf file. It is not an actual brush, but you can open it, Edit-Copy Visible, and as many of you know, it goes to the clipboard and can be selected as a brush. I recommend setting the spacing to 1 and Hardness slider to about 90 - 95 while using this "tube".
File comment: Open file, select Edit/Copy Visible, set spacing to 1, Hardness to 95ish, open a drawing, and while using the brush, select the ring of color, then paint away!
ringofcolor.xcf [202.35 KiB]
Downloaded 204 times
 Post subject: Re: Brush Resource For Colorful Tubes
PostPosted: Sun Jun 07, 2020 5:53 pm  (#2)
Made it into an eye brush.
PostPosted: Sun Jun 07, 2020 6:07 pm  (#3)
I downloaded Affinity Designer, contemplating buying those brushes just so I can see how the dynamic brush engine works. Glad you're having fun.
PostPosted: Mon Jun 08, 2020 2:07 am  (#4)
absolutely T for tremendous, racer ! :jumpclap
PostPosted: Mon Jun 08, 2020 2:12 am  (#5)
Designer is the vector variant of the Affinity suite. Its mostly a painting and illustrating program. Photo is more the equivalent to Gimp.
Doesnt relly matter because both programs use the same brush engine for pixelbrushes. In Designer you have to switch to the Pixelpersona.
AFAIK, you can use the trial version for 14 days without any limitations, and if i remember correctly its also at a 50% discount while the covid crisis lasts.
EDIT: the trial has been also extended to 90 days
The wispy brush i showcased is from the xenon-brush-pack-bundle.
PostPosted: Mon Jun 08, 2020 5:35 am  (#6)
I thought that I could play here too, in glass of course. A colourful glass smiley brush; makes tubes at 5, 10 15 spacing intervals or just by itself.
omg_glass_smiley_sunset26.zip [334.36 KiB]
Downloaded 252 times
PostPosted: Mon Jun 08, 2020 6:44 am  (#7)
I wonder why mahvin's brush has artifacts on the sides, while omg's looks super smooth.
PostPosted: Mon Jun 08, 2020 9:36 am  (#8)
The bump map shading.
