It is currently Wed Nov 11, 2026 3:16 pm
 Post subject: Two Animated Brushes
PostPosted: Mon Jun 08, 2020 9:02 pm  (#1)
Knock yourselves out. They go in your Brushes folder.
mura4.gih [2.85 MiB]
Downloaded 323 times
mura5.gih [5.22 MiB]
Downloaded 1469 times
 Post subject: Re: Two Animated Brushes
PostPosted: Tue Jun 09, 2020 5:52 am  (#2)
Thanks, that gave me some ideas.
Star.gih.zip [698.09 KiB]
Downloaded 304 times
PostPosted: Tue Jun 09, 2020 6:08 am  (#3)
And now the chrome version...
Star-Chrome.gih.zip [1.16 MiB]
Downloaded 307 times
PostPosted: Tue Jun 09, 2020 6:22 am  (#4)
looks straight out of an H.P. Lovecraft story :bigthup
PostPosted: Tue Jun 09, 2020 6:24 am  (#5)
Theres something strange about this brush. Its cut off at cell 35, but its not visible when you make a paintstroke..
PostPosted: Tue Jun 09, 2020 6:32 am  (#6)
Probably because he didn't resize the the layers to image size. There is a plugin to batch that operation. It's installed in the "Image" menu list if you have it.
PostPosted: Tue Jun 09, 2020 9:43 am  (#7)
Yep. I forgot to resize the layers to the image. These things happen when you rely on scripts and plugins to make your work go faster. Mura Meister copies script from Tin sped things up quite a bit. Thank you for pointing it out, I've fixed it and will now update the link.
PostPosted: Tue Jun 09, 2020 9:54 am  (#8)
More nice brushes, thank you mahvin and racer-x!
PostPosted: Tue Jun 09, 2020 10:22 am  (#9)
You're welcome !
I have a question about the mura4 brush:
i tried to modify your brush so that one could use it for a rope effect (in grayscale - i liked the green part best).
However a straight rotation of 4° per cell doesnt seem to recreate the effect. When i click the preview of your brush, it seems there is also a shrink and then regrow to the original size effect included.
Is that correct ?
If so, what values did you use for the resize ?
PostPosted: Tue Jun 09, 2020 11:40 am  (#10)
I didn't use any resizing. It must be an after effect of the script copying and turning each layer. Blur Artifacts?
PostPosted: Tue Jun 09, 2020 11:43 am  (#11)
I call this one Cable, but twisted snakes would probably be a good name too...
Cable-copper.gih.zip [1.57 MiB]
Downloaded 233 times
PostPosted: Tue Jun 09, 2020 11:54 am  (#12)
Very strange... this is the result im getting...
Rope1.zip [1.24 MiB]
Downloaded 249 times
PostPosted: Tue Jun 09, 2020 12:05 pm  (#13)
It's unique, though. I'm looking at it and thinking maybe two circles should be slightly darker than the other two, to create a contrast separation.
PostPosted: Tue Jun 09, 2020 2:40 pm  (#14)
Peace is golden.....
PostPosted: Tue Jun 09, 2020 2:41 pm  (#15)
That is so cool.
