It is currently Tue Nov 10, 2026 6:50 am
 Post subject: Animated brush
PostPosted: Mon Nov 30, 2020 4:41 am  (#1)
Is there a tutorial for a similar animation brush .. how do you get the rotated effect?
 Post subject: Re: Animated brush
PostPosted: Mon Nov 30, 2020 8:51 am  (#2)
I recently did something similar here:
viewtopic.php?f=11&t=18573&p=255861#p255861
It can be done with an animated (.gih) brush, but probably better using a static (.gbr) brush and dynamics
I have created a small demo. Included in the zip file:
brush (TwistedRope.gbr – put it in the brush folder of your profile)
dynamic (TwistedRope.gdyn – put in the dynamics folder of your profile)
Dynamics are easy to make, but I have included it for the demo.
Have a good look at the settings in the attached image.
TwistedRope.zip [8.73 KiB]
Downloaded 419 times
PostPosted: Mon Nov 30, 2020 11:07 am  (#3)
Blighty II, I really liked the brush, thanks for sharing it.
The previous image was made in the triangular wave mode.
This, following the orientation correctly, was done in Sawtooth wave mode
PostPosted: Mon Nov 30, 2020 12:05 pm  (#4)
thank you ... I'm going to try
PostPosted: Mon Nov 30, 2020 3:15 pm  (#5)
The actual brush you show was one I made using four color circles and rotating each one 10 degrees for 360 degrees using the Mura Meister script.
PostPosted: Tue Dec 01, 2020 4:16 am  (#6)
Mahvin, I saw it was your edit. But I couldn't figure it out with Mura meister ... It's clear to me this way.
PostPosted: Tue Dec 01, 2020 6:32 am  (#7)
This "Twisted Rope" dynamics makes interesting effects with various brushes.
PostPosted: Tue Dec 01, 2020 7:17 am  (#8)
Another interesting one.
PostPosted: Tue Dec 01, 2020 8:39 am  (#9)
Racer-x, it reminded me of an edit I made when testing Skinnyhouse's Path Scale copy rotate Shift Walk for Gimp. Although different, your image reminded me of this https://gimplearn.net/viewtopic.php?p=32156#p32156 .
A good idea to try other brushes using TwistedRope Dynamics! I'll try it.
Following mahvin's tip I ended up creating a gih version using the Mura Meister script. It has the advantage that I don't need to memorize the Dynamic brush settings (Fade lenght, sawtooth wave, spacing, dynamic used, etc.).
But I keep both brushes, although they are similar they are not identical.
PostPosted: Wed Mar 05, 2025 8:03 am  (#10)
Really cool, Blighty II. Thanks a lot. :tyspin
