It is currently Wed Nov 11, 2026 8:14 am
 Post subject: Frame brushes
PostPosted: Fri Nov 16, 2018 9:21 pm  (#1)
Last Year I made some frames but they were too large to upload them here. Then I had a thought (only recently) I could turn them into brushes! Problem is they have been condensed a bit now and cannot be used much larger than double their default size. I did a few and added some of my own extras onto some. First lot are ones I added onto. Second lot is mostly plain frames I do have a couple of zip folders if anyone shows any interest. I know I will probably not use them and have them in my brushes now :oops: :hehe these are only rectangle ones. I have some other shapes as well (flower, heart, star, square, circle, oval & triangle) but haven't changed them into brushes yet. Took ages with the rectangle ones.
Uploaded to Deviant art https://www.deviantart.com/sallyannester
I think there may be more here than those I posted above. (In lots of four except the last one. I couldn't find them on my computer so downloaded the lot I have at Deviant art plus the ones I have in my brushes folder
File comment: Turing matt & ying yang, Turing, Yellow skull & crossbones, Yingyang plus and yingyang.
Rec yingyang3.zip [224.83 KiB]
Downloaded 58 times
File comment: Paisley, red matt & paisley, red matt & pinwheels plus skull & cross bones
Rec skull & crossbones16.zip [693.14 KiB]
Downloaded 57 times
File comment: Gold plates, happy smileies light blue lace plus matt double heart
Rec matt dbl heart59.zip [644.88 KiB]
Downloaded 59 times
File comment: Dark pink lace, fractal, gold hearts plus gold pattern
Rec gold pattern68.zip [507.41 KiB]
Downloaded 50 times
File comment: Christmas time, Cream matt with skull & crossbones, dark blue matt & light blue lace plus dark brown matt & material
Rec dk brown matt and material79.zip [314.82 KiB]
Downloaded 53 times
File comment: 18, Autumn leaves, Black, white & gold plus checkerboard
Rec checkerboard115.zip [273.53 KiB]
Downloaded 51 times
File comment: Pattern, plasma, purple & blue plus Purple matt & paisley
Rec Purple matt and paisley31.zip [804.44 KiB]
Downloaded 60 times
 Post subject: Re: Frame brushes
PostPosted: Fri Nov 16, 2018 10:13 pm  (#2)
Cool looking brushes.
PostPosted: Sun Nov 18, 2018 3:51 am  (#3)
Thanks Sallyanne.
PostPosted: Sun Nov 18, 2018 5:06 am  (#4)
Thank you both :).
Would you believe (I guess you would)
I made some of these with brushes along paths. But sadly I don't have them anymore.
PostPosted: Sun Nov 18, 2018 9:29 am  (#5)
Thank you so much Sallyanne. Very nice frames. :tyspin :coolthup
