It is currently Tue Nov 10, 2026 6:28 am
 Post subject: Wool thread brush
PostPosted: Thu Feb 06, 2025 11:11 am  (#1)
I came across this and I want to make a brush or a pattern that looks like the wool around the letters. I have tried a few things but I haven't really succeeded yet. Does anyone have any tips for me?
 Post subject: Re: Wool thread brush
PostPosted: Thu Feb 06, 2025 5:14 pm  (#2)
Hi Jappaloe63. Use this pattern I created out of a yarn roll. Depending of the size of the text you're creating you can use the LayerFx plugin.
This is a sample using LayerFx. (Maybe you can create this effect more realistic than mine)
PostPosted: Fri Feb 07, 2025 1:50 am  (#3)
Thank you Pocholo.. have been looking for a long time
PostPosted: Fri Feb 07, 2025 4:00 am  (#4)
Online
Hi Jappaloe...
I have an animated brush that could possibly be edited to produce the sort of effect you want.
Currently it is intended to produce golden threads so colour is applied using mode and desaturation but it would be easy enough to create a greyscale version (perhaps add a bit of blur to soften the outline) to paint in the current colour.
If you use appropriate dynamics and spacing you could achieve something like your desired effect.
The brush...
wisp.gih [1.68 MiB]
Downloaded 378 times
PostPosted: Fri Feb 07, 2025 6:35 am  (#5)
Thank you Skinnyhouse ... I'm definitely going to try it!
PostPosted: Fri Feb 07, 2025 12:34 pm  (#6)
Online
PostPosted: Fri Feb 07, 2025 12:36 pm  (#7)
Online
A greyscale brush ...
wisp-greyscale-compressed.gih [232.57 KiB]
Downloaded 194 times
PostPosted: Fri Feb 07, 2025 1:13 pm  (#8)
Here is a pattern i created in Filter Forge Pro 14. - Not seamless but big enough for smaller text i believe. Just rotate and re colorize to your liking. :bigthup
I tried to make it bigger but Gimp Chat won't allow images that large.
PostPosted: Mon Feb 10, 2025 11:30 am  (#9)
Tried them all. I also did some searching myself and it was a satisfying result.
PostPosted: Mon Feb 10, 2025 2:38 pm  (#10)
Jappaloe63, Very nice outcome :coolthup
