It is currently Tue Nov 10, 2026 6:28 am
 Post subject: Alien Flora
PostPosted: Mon Jun 29, 2026 4:42 am  (#1)
Since I really like fantasy, I couldn't miss the opportunity to quickly create some brushes (gbr) from Lylejk & DDG painting:
viewtopic.php?f=22&t=13002&p=303761#p302829
Alien flora.7z [4.73 MiB]
Downloaded 229 times
 Post subject: Re: Alien Flora
PostPosted: Mon Jun 29, 2026 5:04 am  (#2)
Thankyou MareroQ :)
PostPosted: Mon Jun 29, 2026 8:19 am  (#3)
Thank you. Very cool.
PostPosted: Mon Jun 29, 2026 8:45 am  (#4)
Thank you so much. A very nice work, MareroQ . :tyspin
Lyle, thanks a lot, too.
PostPosted: Mon Jun 29, 2026 7:13 pm  (#5)
PostPosted: Mon Jun 29, 2026 7:46 pm  (#6)
Nice, MareoQ; like the animation, too, Tas. :)
PostPosted: Mon Jun 29, 2026 8:22 pm  (#7)
OK; had to tape all the brushes (and had to reduce the size of one of the brushes), ran Pan to Bow, and then Drosted the result. It's what I do. lol
I know; the objects ended up a bit tiny, but had to reduce the size of the image (nearly 5500X5500 before reduction; lol). :)
PostPosted: Mon Jun 29, 2026 11:27 pm  (#8)
Thanks MareroQ! :)
I have some ideas for Custom Fonts with some of these. :bigthup
PostPosted: Mon Jun 29, 2026 11:29 pm  (#9)
Thanks MareroQ.
PostPosted: Wed Jul 01, 2026 5:42 am  (#10)
Just 'tried' to use the brushes to make a fantasy background
Image Using gimp and background from GMIC
ImageUsing gimp and background from the net (creative commons)
PostPosted: Wed Jul 01, 2026 12:01 pm  (#11)
[ Image ] Using gimp and background from GMIC
[ Image ]Using gimp and background from the net (creative commons)
Like the colorful results, Sallyanne. :)
PostPosted: Wed Jul 01, 2026 6:55 pm  (#12)
Colorizing the brushes is a good idea Sallyanne.
PostPosted: Wed Jul 01, 2026 8:16 pm  (#13)
I didn't each, just used a plasma layer and layer mode - I guess you could do just as good or probably even better with a gradient. I was looking for a specific look which I didn't really achieve.
