It is currently Tue Nov 10, 2026 8:18 am
 Post subject: TapRats Brush
PostPosted: Fri Jun 01, 2012 7:03 pm  (#1)
After playing with the new program TapRats.
I decided to create a brush because of the transparency in the image i got a pretty neat brush for all kinds of texturing. :)
Image example
TapRats_Brush_RD14.zip [1.07 MiB]
Downloaded 188 times
You can make different colored ones by just adding white bg desaturating the image and flatten it.
Save as grayscale (Image>Mode>Grayscale
Then edit>Copy visible>Edit>Paste as new Brush
Name the brush and you are all set. :)
Here is one for you if you are too lazy.. :lol
TapRats_Color_RD17.gbr [976.61 KiB]
Downloaded 166 times
Enjoy!
 Post subject: Re: TapRats Brush
PostPosted: Fri Jun 01, 2012 7:07 pm  (#2)
That is really cool Rod, thanks. I like the way you can do an edge with it.
PostPosted: Fri Jun 01, 2012 7:16 pm  (#3)
Nice looking brush Rod.
PostPosted: Fri Jun 01, 2012 7:18 pm  (#4)
Thanks Molly, and Lyle. I added a color brush too. (First post)
It almost reminds me of yarn or knitting work. :)
