It is currently Tue Nov 10, 2026 8:03 am
 Post subject: shatter brush
PostPosted: Sat Jul 14, 2012 8:20 am  (#1)
Not posting a brush, just asking if anyone has one to share. I want to make a pic that makes it look like a person is disintegrating and the shattered pieces are flying off. I have a tutorial but they use a splatter brush. It's ok, but I would rather have a brush that is more like shards/pieces of glass flying off rather than splats flying off. I have looked all over but haven't found one yet.
 Post subject: Re: shatter brush
PostPosted: Sat Jul 14, 2012 8:47 am  (#2)
I'll have a go at making some.
PostPosted: Sat Jul 14, 2012 2:51 pm  (#3)
Try the confetti brush 2-ton. :)
PostPosted: Sat Jul 14, 2012 10:59 pm  (#4)
confetti looks too rounded, I was hoping to find one that looked like pieces of shattered glass spraying out, sharp and multi-shaped.
PostPosted: Sun Jul 15, 2012 12:09 am  (#5)
This may be what you are looking for then. :)
http://www.brusheezy.com/brushes/13975- ... hes-vol--2
This is from the particle-2 pack and brush number 007
PostPosted: Sun Jul 15, 2012 12:56 am  (#6)
Deviant is your friend. :)
http://scully7491.deviantart.com/art/Br ... es-8794316
PostPosted: Sun Jul 15, 2012 9:58 am  (#7)
awesome, both brushes look good, I will try them out tonight! Thanks...don't know why I couldn't find any!!! I just don't have the hunting skills that you guys do!
PostPosted: Sun Jul 15, 2012 10:15 am  (#8)
I had a search and couldn't find these either. It would be good if DA had a categorized resources index.
PostPosted: Sun Jul 15, 2012 10:56 am  (#9)
uh oh, that particle brush is a unix folder, I stashed it on desktop but don't know how to open it or put it into my gimp brush folder. Can I put the whole folder into the brush folder in 2.6 and 2.8?
PostPosted: Sun Jul 15, 2012 11:12 am  (#10)
Something has gone wrong, it should be a zip file.
try this (my very little used minus account)
http://min.us/m93z7TAmx
PostPosted: Sun Jul 15, 2012 11:38 am  (#11)
I downloaded it and extracted it and then plunked the abr into my brushes folder.
PostPosted: Sun Jul 15, 2012 5:10 pm  (#12)
Thanks Rich, I was able to grab that, although I have no idea how many brushes it is, it's not a zip file.
PostPosted: Sun Jul 15, 2012 5:25 pm  (#13)
There are 15 broken glass files in that zip file 2.ton
PostPosted: Sun Jul 15, 2012 5:27 pm  (#14)
It came in a zip folder when I downloaded it Rich.
PostPosted: Sun Jul 15, 2012 5:59 pm  (#15)
I tried the brushes...one problem is that since they are 'glass' they are not totally opaque, which is what I need. I want to find something like a splatter brush, fully opaque, with sharp shard sprays instead of roundish splat sprays. Looks like this is going to be quit a hunt! I could use splatter brushes, I just think it would look better if someones was shattering apart that the pieces would be sharp.
PostPosted: Sun Jul 15, 2012 6:07 pm  (#16)
Can you not create a brush by painting with one of the existing brushes then using threshold on it?
PostPosted: Sun Jul 15, 2012 8:22 pm  (#17)
the more transparent parts stay white while the grayer parts turn black. But it's a good idea so I will fiddle around with that!
PostPosted: Thu Jul 19, 2012 9:44 pm  (#18)
Did this one for 2-ton. Click here for details. :)
PostPosted: Thu Jul 19, 2012 9:49 pm  (#19)
downloaded! will play around to get them opaque.
PostPosted: Thu Jul 19, 2012 11:13 pm  (#20)
Not sure if something like this will work for you. I just whipped it up. It is a random single shard hose. You might use it to create larger clumps.
shards.zip [111.99 KiB]
Downloaded 221 times
-Rob A>
