It is currently Tue Nov 10, 2026 8:18 am
 Post subject: Sparkler Brushes
PostPosted: Mon Sep 24, 2012 5:36 pm  (#1)
As requested in another thread, viewtopic.php?f=11&t=5346&start=0, I made some sparkler brushes that are not really the kind you see with grinding or welding, but more like the fireworks kind of magnesium sparklers. Although you could use still use them for that if you wanted to I guess.
Sparkler Brushes by Draconian.7z [2.49 MiB]
Downloaded 363 times
 Post subject: Re: Sparkler Brushes
PostPosted: Mon Sep 24, 2012 5:43 pm  (#2)
Thank you Drac.
PostPosted: Mon Sep 24, 2012 6:11 pm  (#3)
Thanks Drac. Those are very pretty.
PostPosted: Mon Sep 24, 2012 6:49 pm  (#4)
thank you !!!
PostPosted: Mon Sep 24, 2012 7:13 pm  (#5)
Thanks Drac. Going to PM you a request too. :)
PostPosted: Mon Sep 24, 2012 7:15 pm  (#6)
draconian: great brushes, just what i needed :)!
lylejk: that's very prettily done!
PostPosted: Mon Sep 24, 2012 8:02 pm  (#7)
also useful for making grungy textures with Dynamics Random and Spread
PostPosted: Mon Sep 24, 2012 8:15 pm  (#8)
Thanks, Drac, you are da man!
Urm, how does one open 7-zip on a mac? I can't find an application that will open it.
*nvr mind, I found an app in the app store that did the trick.
PostPosted: Tue Sep 25, 2012 5:25 am  (#9)
G'mornin' everyone. :mcof
Thanks. I'm glad everyone liked them. I had no idea a couple of dumb brushes would get this kind of response.
Esper - cool idea to use for grunge. :bigthup
