It is currently Tue Nov 10, 2026 8:19 am
 Post subject: Animated Streamer Brushes
PostPosted: Wed Nov 14, 2012 2:10 am  (#1)
Whilst playing around with alc's Metal Ring or Sphere Tutorial and the thread going into using spirals, I though how much they looked like the streamers found on birthday party items.
So I decided to create som animated brushes to reflect this, there a four brushes in the pack, a single brush for each spiral shape then a single brush containing all the spirals together.
They are in greyscale mode so can be coloured as you like. Just realised that the greyscale brushes are semi transparent because of the way gimp works, hence if you use a darker background it shows through and they don't look so good, so have created another set that are purely black and white.
Here is an example of the Greyscale brushes.....
Here is an example of the Black and White brushes....
And here is the link to the spiral brush folder, simply unzip and place in your brushes folder.
Streamer Brushes 01.zip [383.31 KiB]
Downloaded 298 times
Streamer Brushes.zip [494.94 KiB]
Downloaded 243 times
 Post subject: Re: Animated Streamer Brushes
PostPosted: Wed Nov 14, 2012 2:21 am  (#2)
Thank you He4rty they look great
PostPosted: Wed Nov 14, 2012 4:07 am  (#3)
Thanks sweetheart :)
PostPosted: Wed Nov 14, 2012 4:11 am  (#4)
Thanks for the comments just updated first post to correct a slight flaw.
PostPosted: Wed Nov 14, 2012 11:31 am  (#5)
Really nice set of brushes.
I knew you were up to something ;) after all that experimentation with spirals :)
PostPosted: Thu Nov 15, 2012 1:15 am  (#6)
Thanks for the comments, do really like the first set with the highlights and all, its a shame they are semi transparent.
Possibly thinking of making a set coloured, using twelve evenly spaced hues.
PostPosted: Thu Nov 15, 2012 8:59 am  (#7)
Lovely brushes he4rty. Thank you
PostPosted: Thu Nov 15, 2012 9:34 am  (#8)
Thanks he4rty!
PostPosted: Fri Nov 16, 2012 7:36 am  (#9)
You're such a great asset to GimpChat he4rty. Thanks for these.
