Hi, I was looking at some PS tuts and in one tutorial they required the use of a word brush. So I made two Lorem Ipsum brushes to use as a text filler. One is an Italic Script brush and the other is a Roman type brush. The brushes are rather large at normal size , so that they can be used at smaller sizes as well without losing too much definition. 400 X 150 and optimum spacing is 100% to give a nice continuous sentence. I also recommend the use of the Shift button to make the words flow in a nice horizontal or vertical direction. I include an image illustrating some uses of the brushes and the brushes as well. If you can use these brushes, please upload the brushes and use in any way you wish.
LSRoman.gih [738.26 KiB]
Downloaded 235 times
LILucida .gih [1.03 MiB]
Downloaded 231 times
