It is currently Mon Nov 23, 2026 1:31 pm
 Post subject: Gimp Hyperspace Brushes
PostPosted: Tue Mar 26, 2013 5:32 pm  (#1)
These brushes were based on a photoshop tutorial I saw about creating an explosion. I adapted the tutorial for Gimp to create these brushes.
There are 13 brushes, all pretty large, (1200 X 1200) except for one which is (614 X 383). One of the brushes is "gray scale" the others are all "RGB"; I also included preview images for each brush.
You can view an example of how I used one of these brushes, on an image I colored here @ deviantArt.com... http://geosammy.deviantart.com/art/Iron ... -313048906
I don't have any idea what you might use them for, but that's totally up to you. :hehe
You can pick them up here @ dropbox.com... https://www.dropbox.com/s/emzg7qtsxqnb5 ... rushes.zip
 Post subject: Re: Gimp Hyperspace Brushes
PostPosted: Tue Mar 26, 2013 7:45 pm  (#2)
gramg wrote:
Thanks so much...I hope the one you make the great flashing stars with is in there.
@ Gramg,
Yes it sure is, the preview image I used in this post is also part of the brush set.
It looks like this image below without the text...
PostPosted: Tue Mar 26, 2013 8:09 pm  (#3)
Those are awesome, Wallace. I had to look at all of them. :mrgreen:
PostPosted: Tue Mar 26, 2013 8:10 pm  (#4)
@ Oregonian,
Glad you like them, "enjoy"... ;)
PostPosted: Sun Apr 07, 2013 1:01 pm  (#5)
Cool ,thank you
PostPosted: Sun Apr 07, 2013 1:06 pm  (#6)
PhotoComix wrote:
Cool ,thank you
@PhotoComix,
Your welcome, you can also pick them up at deviantArt for 10 points. :hehe
