It is currently Wed Nov 18, 2026 4:46 pm
 Post subject: GIMP Arrow Brushes
PostPosted: Sun Apr 11, 2010 6:42 pm  (#1)
Gimp Arrow Brushes
Have arrow brushes at your fingertips when you need one. The zipped folder has three different styles of brushes and each style has 8 different orientations: W, E, S, N, NW, NE, SW, SE. I named the orientations after compass points: West, East, South, North, North-West, North-East, South-West, South-East.
There is a very small, cursor-sized brush and two larger brushes with arrow tips and wing tips in the Arrow Brushes folder in the Zipped file.
The brushes come as regular black brushes or grayscale brushes. They have separate folders in the zip file.
Download the attached zip file.
Arrow Brushes.zip [20.81 KiB]
Downloaded 5335 times
 Post subject: Re: GIMP Arrow Brushes
PostPosted: Mon Apr 12, 2010 3:44 am  (#2)
very nice "O" I grabbed mine. :cu
PostPosted: Sat Apr 17, 2010 5:26 pm  (#3)
Thanks O can never have enough arrow brushes!
PostPosted: Sat Apr 17, 2010 7:01 pm  (#4)
Question...I was trying out the arrow brushes today, and they are black no matter what my foreground color is. How do I make them another color?
PostPosted: Sat Apr 17, 2010 7:13 pm  (#5)
Same thing with mine to....toni
PostPosted: Sat Apr 17, 2010 7:13 pm  (#6)
In brush Dynamics, tick the color box in Velocity and the brush will take the fg color.
If you tick the color box in Pressure, the brush will take the bg color.
I thought about making the brushes grayscale so they would automatically take the fg color but thought again that people might not want to add 24 brushes to their folder and they could open a brush from a folder and copy to clipboard and use it as a brush that way. Could make a set of grayscales.
PostPosted: Sat Apr 17, 2010 7:19 pm  (#7)
hot dawg that worked woo hoo.....
PostPosted: Sat Apr 17, 2010 7:54 pm  (#8)
OK, Arrow Brushes.zip has been updated to contain a folder of regular black brushes and a folder of grayscale brushes.
If you want the grayscale brushes you will need to download the zip file again.
PostPosted: Sat Apr 17, 2010 8:37 pm  (#9)
I don't know where brush dynamics are.
PostPosted: Sat Apr 17, 2010 8:45 pm  (#10)
It's probably because you have gimp 2.4.
In the brush toolbox there's a Dynamics button with a dropdown list.
I think you have access to something in 2.4 in the toolbox for color, don't you. I vaguely remember clicking something that made the brush use the bg color.
You can re-download the zip file in the first post and put the grayscale brushes in your brushes folder. They will take on the fg color. There's a separate folder in the zip file that is Grayscale Brushes.
PostPosted: Sat Apr 17, 2010 9:57 pm  (#11)
Thanks! That did the trick!
PostPosted: Sat Apr 17, 2010 9:59 pm  (#12)
What did? Please share. :-D
PostPosted: Sat Apr 17, 2010 10:55 pm  (#13)
...the greyscale brushes that use the foreground colors. Now I can have colored arrows.
PostPosted: Wed May 26, 2010 1:33 am  (#14)
thank you these are very nice =)
PostPosted: Wed May 26, 2010 8:44 am  (#15)
got em, thanks. I need arrows now and then and am too lazy to make them.
PostPosted: Tue Oct 14, 2014 9:12 pm  (#16)
:tyspin Oregonian for the Arrow brushes :)
Some think inside the box, others think outside the box.
I think, what box ~ why limit yourself.
PostPosted: Tue Oct 14, 2014 11:08 pm  (#17)
You are welcome. I'd forgotten all about these. :pengy
