It is currently Wed Nov 18, 2026 10:35 am
 Post subject: Another Christmas Set Animated Brush
PostPosted: Sat Dec 25, 2010 5:40 pm  (#1)
Found this one hiding on my old hard drive. Wish I had had more time to do these "before" Christmas.
christmasset.gih [2.06 MiB]
Downloaded 361 times
 Post subject: Re: Another Christmas Set Animated Brush
PostPosted: Sat Dec 25, 2010 6:28 pm  (#2)
Cool! Thanks to you, mahvin, I think I'm all set up for next Christmas. :mrgreen:
PostPosted: Sat Dec 25, 2010 6:41 pm  (#3)
If you come across any picture tubes online anywhere and you want to use them as brushes, two things you need to know, providing you have Paint Shop Pro:
1. They have to have transparent backgrounds and can only be a single layer. I convert them from tubes into .png files, then
2. I call up Guillotine into Layers (found here: http://registry.gimp.org/node/19886) and can be found in Image - Transform when loaded.
On occasion, I'll find some who actually upload their tubes online under the .png format. If Gnu Tux doesn't have a problem with it, you could add a topic folder for Picture Tubes that need converting from the .tub or .psptube format, and when I get time, I'll convert them into GIMP brushes. There are boatloads of picture tubes on the internet, of which many are exceptional quality and would make great brushes.
I tend to stay away from the general assortments, but I do find the seasonal and holiday tubes to be of great interest.
PostPosted: Sun Dec 26, 2010 2:34 am  (#4)
I always wondered how to change Paintshop Pro brushes into GBR.I never thought of changing them to PNG first.
Thanks mahvin for the info, and the great brush sets. =)
