It is currently Tue Nov 10, 2026 8:21 am
 Post subject: Animated Tapuz emoticons brushes + explanations
PostPosted: Fri Feb 07, 2014 2:42 pm  (#1)
Inspired by Wallace's Animated Pepper brush, i decided to try making an animated emoticons brush;
here are is the brush in action:
random brush painting:
linear:
random icons:
2 brushes are attached:
"linear", and "random placement".
license: these icons were taken from http://www.tapuz.co.il; i think it's creative commons, so respect their license please.
File comment: original xcf
tapuz-emo-brush.xcf [47.9 KiB]
Downloaded 164 times
tapuz-emo-brush.gih [153.77 KiB]
Downloaded 169 times
File comment: tapuz.co.il emoticons brush (linear)
tapuz-emo-brush-linear.gih [50.77 KiB]
Downloaded 179 times
 Post subject: Re: Animated Tapuz emoticons brushes + explanations
PostPosted: Fri Feb 07, 2014 2:49 pm  (#2)
few notes:
to create the brush, i
1) downloaded all the icons,
2) and then Gimp > File > Open As Layers
and multiple-selected all the icons
3) Export As ... > File type: GIH
4) There are several export options;
- the most important were: spacing (in this case it was desireable to choose more than 100%)
- and random. IMMV
For the more scattered brush,
1) i enlarged the canvas and all layers to 2-3 times larger than the icons
2) manually moved each icon/layer to a random location
this spreads the icons randomally (see XCF)
for the crowd image, i added the icons in 3 layers:
the "far" layer is "dodged",
the "middle" layers is "lighten"
the "front" layer is left as it was.
PostPosted: Fri Feb 07, 2014 3:23 pm  (#3)
Yaay, Really cool stuff!
PostPosted: Fri Feb 07, 2014 4:20 pm  (#4)
I didn't think what I did would inspire anyone, and I'm flattered.
