It is currently Tue Nov 10, 2026 8:22 am
 Post subject: patterns, and strawberry brushes
PostPosted: Wed Mar 05, 2014 4:34 pm  (#1)
:bump
I made some strawberry brushes, seamless patterns and spheres for anyone interesting in grabbing them.
Strawberries2.7z [1.69 MiB]
Downloaded 373 times
 Post subject: Re: patterns, and strawberry brushes
PostPosted: Wed Mar 05, 2014 8:13 pm  (#2)
Thank you molly - just "picked"!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Thu Mar 06, 2014 12:53 am  (#3)
Thanks Molly. Created a packed strawberry texture and then double-poled drosted it. :)
PostPosted: Thu Mar 06, 2014 1:28 am  (#4)
Molly you thought of everything even an environment map
PostPosted: Thu Mar 06, 2014 4:02 am  (#5)
Thank you Lyle, Love yur Droste.
Graechan, did you use that strawberry time as environment map? I never thought of using it for that, cool.
PostPosted: Thu Mar 06, 2014 4:45 am  (#6)
Ok, I downloaded the pack, but I have no idea where the strawberry, strawberry seamless, and the sphere images go. What folders do they belong in?
PostPosted: Thu Mar 06, 2014 4:51 am  (#7)
I put the seamless patterns in my user gimp patterns folder and the gbr goes into brushes.
You can put the spheres wherever you want, I just made them out of the seamless patterns to show that they were seamless. Thanks for downloading mackenzieh.
PostPosted: Thu Mar 06, 2014 4:59 am  (#8)
I didn't get the patterns... just the image files of the strawberry seamless. Do the images work as patterns or do they have to be converted into a different file format?
PostPosted: Thu Mar 06, 2014 5:25 am  (#9)
Yes, I just leave the png, or jpg extension on the seamless patterns, and place them in my patterns folder. You can make them as a .pat if you want.
Just open the pattern in gimp,
Edit: copy > edit paste as new pattern, Name it. Image
PostPosted: Thu Mar 06, 2014 5:58 am  (#10)
I thought you deliberately included the sphere for use as an environment map in Tux's bevel reflect script
PostPosted: Thu Mar 06, 2014 6:06 am  (#11)
No I didn't but you put it to good use. I am having a heck of a time figuring out all those settings. I want mine to be round and shiny like a worm, I finally got it but don't remember what I did.
PostPosted: Thu Mar 06, 2014 9:21 am  (#12)
Thank You Molly
PostPosted: Thu Mar 06, 2014 9:48 am  (#13)
Hey, that is very cool Pirate. nice job.
PostPosted: Thu Mar 06, 2014 10:14 am  (#14)
PostPosted: Thu Mar 06, 2014 3:33 pm  (#15)
molly: nice! i made you a cake with the brushes :)
PostPosted: Thu Mar 06, 2014 3:39 pm  (#16)
OMG anMal, if you only knew how much I am addicted to sweets. That looks sooooo yummy. Thanks
