It is currently Tue Nov 17, 2026 10:50 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: Image Watermark Plug-in - My 1st GIMP 3.0 plug-in
PostPosted: Wed Nov 06, 2024 10:04 pm  (#1)
This one client had a watermark automation requirement but it was unique to them
so I am not sharing that but what can be shared is what's common among photo editors, gimp-users who like to apply watermarks like all the time.
So here it is watermark2.py
#!/usr/bin/env python
# Author: Tin Tran
# Created On: 2024.11.03
# License: Open source whatever the GIMP's license is.
# Revisions:
# 0.1 Initial Version
from gimpfu import *
import os
import math
def watermark(image,layer,watermarkpng,opacity,stayaway,location):
    waterimage = pdb.gimp_file_load(watermarkpng,watermarkpng)
    #incase it's xcf with multiple layers, we'll do a from visible so we get result of .xcf
    watermarklayer = pdb.gimp_layer_new_from_visible(waterimage,image,'watermark layer')
    pdb.gimp_image_insert_layer(image,watermarklayer,None,0)
    #move it to lower right
    #move it to desired location (bottom right)
    location = int(location)
    if location == 0:
        pdb.gimp_layer_set_offsets(watermarklayer,image.width-watermarklayer.width-stayaway,image.height-watermarklayer.height-stayaway)
    elif location == 1:
        pdb.gimp_layer_set_offsets(watermarklayer,stayaway,image.height-watermarklayer.height-stayaway)
    elif location == 2:
        pdb.gimp_layer_set_offsets(watermarklayer,image.width-watermarklayer.width-stayaway,stayaway)
    elif location == 3:
        pdb.gimp_layer_set_offsets(watermarklayer,stayaway,stayaway)
    pdb.gimp_layer_set_opacity(watermarklayer,opacity)
register(
    "python_fu_watermark",
    "Puts an image watermark on working image",
    "author name",
    "copyright name",
    "2024.11.06",
    "Watermark",
    "RGB*",      # Alternately use RGB, RGB*, GRAY*, INDEXED etc.
    #INPUT BEGINS
    (PF_IMAGE, "image", "Image", None),
    (PF_DRAWABLE,   "layer", "Drawable", None),
    (PF_FILE, "watermarkpng", "Watermark image(.xcf,.png,.jpg):", "C:\\Users\\tintr\\Desktop\\fiverr\\test\\watermark.png"),
    (PF_SPINNER, "opacity", "Opacity:", 65, (1, 100, 1)),
    (PF_INT, "stayaway", "Stay away from borders (pixels):", 50), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
    (PF_OPTION,"location",   "Location:", 0, ["Lower Right","Lower Left","Upper Right","Upper Left"]), # initially 0th is choice
    #INPUT ENDS
    watermark,
    menu="<Image>/Python-Fu")
main()
# Below is all the example input types for INPUTS for the plug-in which can be cut and pasted into #INPUT BEGINS section and edited to taste (found online years back that I didn't want to constantly look up)
# Since GIMP is free anyways, I thought it would be handy here for me to CUT and PASTE, CHANGE, USE.
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
gimp 3.0 plug-in
#!/usr/bin/env python3
#   Author: Tin Tran
#   watermark3.py Gimp 3.0 plug-in using pdbcall
#   This program is free software: you can redistribute it and/or modify
#   it under the terms of the GNU General Public License as published by
#   the Free Software Foundation; either version 3 of the License, or
#   (at your option) any later version.
#   This program is distributed in the hope that it will be useful,
#   but WITHOUT ANY WARRANTY; without even the implied warranty of
#   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#   GNU General Public License for more details.
#   You should have received a copy of the GNU General Public License
#   along with this program.  If not, see <https://www.gnu.org/licenses/>.
import gi
gi.require_version('Gimp', '3.0')
from gi.repository import Gimp
gi.require_version('GimpUi', '3.0')
from gi.repository import GimpUi
gi.require_version('Gegl', '0.4')
from gi.repository import Gegl
from gi.repository import GObject
from gi.repository import GLib
from gi.repository import Gio
import time
import sys
def N_(message): return message
def _(message): return GLib.dgettext(None, message)
def pdbcall(procedurename,paramnames,paramvalues):
    pdb_proc   = Gimp.get_pdb().lookup_procedure(procedurename)
    pdb_config = pdb_proc.create_config()
    for i in range(0,len(paramnames)):
        pdb_config.set_property(paramnames[i],paramvalues[i])
    return pdb_proc.run(pdb_config)
def watermark(procedure, run_mode, image, drawables, config, data):
    if run_mode == Gimp.RunMode.INTERACTIVE:
        GimpUi.init('python-fu-foggify')
        dialog = GimpUi.ProcedureDialog(procedure=procedure, config=config)
        dialog.fill(None)
        if not dialog.run():
            dialog.destroy()
            return procedure.new_return_values(Gimp.PDBStatusType.CANCEL, GLib.Error())
        else:
            dialog.destroy()
    file     = config.get_property('file')
    stayaway = config.get_property('stayaway')
    opacity  = config.get_property('opacity')
    location = config.get_property('location')
    Gimp.context_push()
    image.undo_group_start()
    if image.get_base_type() is Gimp.ImageBaseType.RGB:
        type = Gimp.ImageType.RGBA_IMAGE
    else:
        type = Gimp.ImageType.GRAYA_IMAGE
    wimage = Gimp.file_load(Gimp.RunMode.NONINTERACTIVE,file)
    print ("Hello")
    #calling pdb with helper function
    result = pdbcall('gimp-layer-new-from-visible',
        ['image','dest-image','name'],
        [wimage,image,"watermarklayer"])
    watermarkLayer = result.index(1)
    # Make layer from visible with destination on existing image
    # pdb_proc   = Gimp.get_pdb().lookup_procedure('gimp-layer-new-from-visible')
    # pdb_config = pdb_proc.create_config()
    # #pdb_config.set_property('run-mode', Gimp.RunMode.NONINTERACTIVE)
    # pdb_config.set_property('image', wimage)
    # pdb_config.set_property('dest-image',image)
    # pdb_config.set_property('name', "watermarklayer")
    # resultCode,watermarkLayer = pdb_proc.run(pdb_config)
    #print (result.index(0)) #it returns a success and a layer in index 0 and 1
    #print (result.index(1))
    #watermarklayer = result.index(1)
    # insert layer on top
    pdbcall('gimp-image-insert-layer',
        ['image','layer','parent','position'],
        [image,watermarkLayer,None,0])
    if location == "lower right":
        pdbcall('gimp-layer-set-offsets',
            ['layer','offx','offy'],
            [watermarkLayer,
            image.get_width()-watermarkLayer.get_width()-stayaway,
            image.get_height()-watermarkLayer.get_height()-stayaway]
    elif location == "lower left":
            [watermarkLayer,
            stayaway,
    elif location == "upper right":
            [watermarkLayer,
            stayaway]
    elif location == "upper left":
            [watermarkLayer,
            stayaway,
            stayaway]
    pdbcall('gimp-layer-set-opacity',
        ['layer','opacity'],
        [watermarkLayer,opacity])
    #for drawable in drawables:
        # fog = Gimp.Layer.new(image, name,
        #                      drawable.get_width(), drawable.get_height(),
        #                      type, opacity,
        #                      Gimp.LayerMode.NORMAL)
        # fog.fill(Gimp.FillType.TRANSPARENT)
        # image.insert_layer(fog, drawable.get_parent(),
        #                    image.get_item_position(drawable))
        # Gimp.context_set_background(color)
        # fog.edit_fill(Gimp.FillType.BACKGROUND)
        # # create a layer mask for the new layer
        # mask = fog.create_mask(0)
        # fog.add_mask(mask)
        # add some clouds to the layer
        # pdb_proc   = Gimp.get_pdb().lookup_procedure('plug-in-plasma')
        # pdb_config.set_property('run-mode', Gimp.RunMode.NONINTERACTIVE)
        # pdb_config.set_property('image', image)
        # pdb_config.set_property('drawable', mask)
        # pdb_config.set_property('seed', int(time.time()))
        # pdb_config.set_property('stayaway',stayaway)
        # pdb_proc.run(pdb_config)
        # apply the clouds to the layer
        # fog.remove_mask(Gimp.MaskApplyMode.APPLY)
        # fog.set_visible(True)
    Gimp.displays_flush()
    image.undo_group_end()
    Gimp.context_pop()
    return procedure.new_return_values(Gimp.PDBStatusType.SUCCESS, GLib.Error())
class Watermark (Gimp.PlugIn):
    ## GimpPlugIn virtual methods ##
    def do_set_i18n(self, procname):
        return True, 'gimp30-python', None
    def do_query_procedures(self):
        return [ 'python-fu-watermark' ]
    def do_create_procedure(self, name):
        Gegl.init(None)
        # _color = Gegl.Color.new("black")
        # _color.set_rgba(0.94, 0.71, 0.27, 1.0)
        procedure = Gimp.ImageProcedure.new(self,name,Gimp.PDBProcType.PLUGIN,watermark,None)
        procedure.set_image_types("RGB*, GRAY*");
        procedure.set_sensitivity_mask (Gimp.ProcedureSensitivityMask.DRAWABLE |
                                        Gimp.ProcedureSensitivityMask.DRAWABLES)
        procedure.set_documentation (_("Add a layer of fog"),
                                     _("Adds a layer of fog to the image."),
                                     name)
        procedure.set_menu_label(_("_Watermark..."))
        procedure.set_attribution("Tin Tran",
                                  "Tin Tran",
                                  "2024.11.07")
        procedure.add_menu_path ("<Image>/Filters/Decor")
        procedure.add_file_argument ("file", _("Watermark Image File"),
                                         _("Watermark Imag File"), GObject.ParamFlags.READWRITE)
        #I thought I could do this below but I was wrong, so wrong
        #procedure.set_property('file',"C:\\Users\\tintr\\Desktop\\fiverr\\test\\watermark.png")
        #procedure.add_string_argument ("name", _("Layer _name"), _("Layer name"),
                                       #_("Clouds"), GObject.ParamFlags.READWRITE)
        #procedure.add_color_argument ("color", _("_Fog color"), _("Fog color"),
                                      #True, _color, GObject.ParamFlags.READWRITE)
        procedure.add_double_argument ("stayaway", _("_Stay away from borders (pixels)"), _("Stay away from borders (pixels)"),
                                       0.0, 500.0, 50.0, GObject.ParamFlags.READWRITE)
        procedure.add_double_argument ("opacity", _("O_pacity"), _("Opacity"),
                                       0.0, 100.0, 100.0, GObject.ParamFlags.READWRITE)
        #Example using choice/options
        choice = Gimp.Choice.new()
        choice.add("lower right", 0, _("Lower Right"), "")
        choice.add("lower left", 1, _("Lower Left"), "")
        choice.add("upper right", 2, _("Upper Right"), "")
        choice.add("upper left", 2, _("Upper Left"), "")
        procedure.add_choice_argument ("location", _("_Location"), _("Location"),
                                           choice, "lower right", GObject.ParamFlags.READWRITE)
        return procedure
Gimp.main(Watermark.__gtype__, sys.argv)
I'll try to make another version using API documented here: https://developer.gimp.org/api/ instead of pdb lookup and call
should be faster.
API version without calling pdb below
#   Author: Tin Tran
#   API version instead pdb calls
import gi
import time
import sys
        GimpUi.init('python-fu-watermark')
        dialog.fill(None)
            dialog.destroy()
        else:
            dialog.destroy()
    Gimp.context_push()
    else:
    #result = pdbcall('gimp-layer-new-from-visible',
    #    ['image','dest-image','name'],
    #    [wimage,image,"watermarklayer"])
    #watermarkLayer = result.index(1)
    #api call instead of above pdbcall
    watermarkLayer = Gimp.Layer.new_from_visible(wimage,image,"watermark layer")
    #pdbcall('gimp-image-insert-layer',
    #    ['image','layer','parent','position'],
    #    [image,watermarkLayer,None,0])
    Gimp.Image.insert_layer(image,watermarkLayer,None,0)
        Gimp.Layer.set_offsets(watermarkLayer,
            image.get_height()-watermarkLayer.get_height()-stayaway)
            stayaway,
            stayaway)
            stayaway,
            stayaway)
    Gimp.Layer.set_opacity(watermarkLayer,opacity)
    Gimp.context_pop()
        Gegl.init(None)
                                     name)
                                  "Tin Tran",
                                  "2024.11.07")
        procedure.add_file_argument ("file", _("_Watermark file"),
                                         _("Watermark file"), GObject.ParamFlags.READWRITE)
        #try a directory/path
        # procedure.add_path_argument ("dirto",_("Water_mark Directory"),_("WaterMark Directory"),True, GObject.ParamFlags.READWRITE)
        procedure.add_double_argument ("stayaway", _("_Stayaway from borders (pixels)"), _("Stayaway from borders (pixels)"),
        return procedure
File comment: gimp 3.0 watermark plug-in - API calls without pdb calls
watermark3.zip [2.58 KiB]
Downloaded 2139 times
File comment: gimp 3.0 plug-in needs to be in subfolder same name as the .py file inside it
watermark3.zip [2.97 KiB]
Downloaded 2102 times
File comment: watermark2.py
watermark2.zip [2 KiB]
Downloaded 1779 times
 Post subject: Re: Image Watermark Plug-in
PostPosted: Thu Nov 07, 2024 3:21 am  (#2)
Great to see you writing plug-ins for Gimp users again Tran. But perhaps you should consider downloading the Gimp-3.0.0 RC 1 version and author them through that API, PDB, and Python-3.11.
Just a thought for future users of 3.0.0.
PostPosted: Thu Nov 07, 2024 6:50 am  (#3)
Thanks Tran, I have saved it and it works great. :hi5
PostPosted: Thu Nov 07, 2024 6:57 am  (#4)
I am trying to delay the process until there are more GIMP 3.0 users. As it is not the official stable download right now.
PostPosted: Thu Nov 07, 2024 6:58 am  (#5)
:hi5
PostPosted: Thu Nov 07, 2024 7:18 am  (#6)
I think i am going to begin re-writing all of mine for version 3. :bigthup
PostPosted: Thu Nov 07, 2024 11:50 am  (#7)
I tried making my watermark one to start and it's hard.
All the c libraries not sure what syntax to use
I am digging in GimpChoice and don't even know how to declare it.
I think I need a whole lot of examples, the foggify.py doesn't seem to have enough syntax for me to work from even for something as simple as watermark. The procedure browser is there but I am not sure how to even call it.
If found some code that called the file selector so I got a file selector going but don't know how to set a default value.
I think it'll be a long while before I can put "I will write you a GIMP 2.10 or GIMP 3.0 Plugin" for my fiverr gig :rofl
I am in the process of installing Eclipse IDE so I can include GIMP source and have friendly autocomplete and all that crazy stuff to program plug-ins now.... and say bye bye to simple text editing
PostPosted: Thu Nov 07, 2024 2:03 pm  (#8)
Tim, have you not found the documentation, yet?
This is where you find it:
https://gitlab.gnome.org/GNOME/gimp/-/artifacts
search for dev-docs ( it's created often, so the direct link changes)
click on the browse icon on the right hand side
search for gimp-api-docs-3.0.0-RC1+git.tar.xz
download the zip, unpack it
You'll find the documentation in
gimp-api-docs-3.0.0-RC1+git/g-ir-docs/html/python/Gimp-3.0
You also find something here: https://developer.gimp.org/api/
( not sure if it's up to date and how often it's renewed)
And if you need python stub files for your editor: Kamil Burda on his github has them:
https://github.com/kamilburda/gimp-miss ... or-pycharm
PostPosted: Thu Nov 07, 2024 5:03 pm  (#9)
Thanks so much
PostPosted: Thu Nov 07, 2024 5:31 pm  (#10)
Updated 1st post to have a version for GIMP 3.0.
I noticed you have to have subfolder name same name as .py file (at least it didn't load for me when i named them differently).
I think I just need to see examples of other parameters which probably exist in GIMP source just got to hunt for them.
I am 50% confident in GIMP 3.0 plug-in now only because I found the example to call pdb procedures.
I made a helper function called pdbcall which handles the setting properties and calling of procedure just I don't have to have a huge block of code each time I want to call pdb procedures.
Are there plans to phase out pdb? I hope not.
PostPosted: Thu Nov 07, 2024 5:43 pm  (#11)
Also I was trying to find a way to default my watermark filename but it's not really required because once you run it once, it remembers the settings even when you restart GIMP so defaults are pointless now since they only used when plug-in is first installed/ran.
That's a very nice feature I think.
PostPosted: Thu Nov 07, 2024 7:07 pm  (#12)
I am wondering if there should be a forum dedicated to GIMP 3.0 Plug-ins
PostPosted: Thu Nov 07, 2024 7:24 pm  (#13)
I want to convert the other plug-in (GIMP-cards) to GIMP 3.0 as well but having a hard time to get the add_path_argument to show up
 Post subject: Re: Image Watermark Plug-in - My 1st GIMP 3.0 plug-in
PostPosted: Thu Nov 07, 2024 9:07 pm  (#14)
Thanks to quietreader for link to API documentation, I have added a version that uses APIs instead of pdbcalls (in first post).
PostPosted: Fri Nov 08, 2024 3:01 am  (#15)
BTW
for gradients, fonts, patterns ....
you find examples here:
https://gitlab.gnome.org/GNOME/gimp/-/b ... -dialog.py
And don't forget the procedure browser. Valuable hints there, too
PostPosted: Fri Nov 08, 2024 3:22 am  (#16)
They use path stuff in histogram-export.py
https://gitlab.gnome.org/GNOME/gimp/-/b ... -export.py
line 109
maybe that helps.
PostPosted: Fri Nov 08, 2024 11:30 am  (#17)
line 109
maybe that helps.
I think that's related to file path in code and not related to GUI that allows users to select a path.
PostPosted: Tue Nov 12, 2024 2:02 pm  (#18)
Hi,
I like this plug-in, and I find it a learning tool.
File comment: It works!
I noticed some problems in the console, and I was wondering what your opinion is. Is this a GIMP issue or is it the plug-in?
File comment: What is going on with the Procedure?
Charles
PostPosted: Tue Nov 12, 2024 3:28 pm  (#19)
It's more of cut and paste and try changing stuff for me...I can never remember all the syntax heheh
PostPosted: Wed Nov 13, 2024 3:27 am  (#20)
I get that. I think with the internet, we need to think of greater things, like idea's for a plug-in, and then document the little things like programmer's do.
I noticed in your watermark API plug-in window that the label on the watermark file widget is missing, and here in this dialog there's an error reporting duplicate labels? I haven't analyzed your code, so I don't know. I did copy, paste, and organize a bunch of it. The reason I ask is that I have a GIMP 3 plug-in that I want to work on, and your code could be very helpful.
Charles
