It is currently Sat Nov 07, 2026 7:33 pm
 Post subject: Flower of Life 2, a Gimp 3 Plug-in
PostPosted: Fri Nov 15, 2024 8:18 am  (#1)
Hi,
I converted and improved my GIMP 2.10 plug-in, Flower-of-Life, to a GIMP 3 compatible version.
This is the plug-in dialog's appearance.
File comment: Created with GTK 3.
Here is an a flower image that was randomly generated.
File comment: The colors were randomized.
Here is the GIMP 3 plug-in.
File comment: Has installation instructions in a "Read Me.txt" file.
flower-of-life-2-plug-in.zip [12.71 KiB]
Downloaded 2093 times
Charles
 Post subject: Re: Flower of Life 2, a Gimp 3 Plug-in
PostPosted: Fri Nov 15, 2024 9:23 am  (#2)
Great job!
PostPosted: Fri Nov 15, 2024 9:33 am  (#3)
Thank you @gasMask
PostPosted: Fri Nov 15, 2024 12:53 pm  (#4)
neat stuff!
PostPosted: Fri Nov 15, 2024 5:33 pm  (#5)
Works well on a Gimp3 appimage on Debian Linux. I had no plug-ins yet so tried this one. I added a GEGL graph filter also.
PostPosted: Fri Nov 15, 2024 10:59 pm  (#6)
Thank you guys for the compliments. I'm posting a new version with a fix and some minor improvements.
File comment: Fix a frame width calculation blunder and improve some minor detail.
Flower-of-Life 2-01.zip [12.87 KiB]
Downloaded 2066 times
Here is the latest version (2024-November-19):
File comment: Fix an alpha problem and remove an experimental circle radius adjustment.
Flower of Life 2.02.zip [13.09 KiB]
Downloaded 845 times
Charles
PostPosted: Fri Dec 20, 2024 6:25 pm  (#7)
Happy holidays,
This latest version has a new preset option. So now when you create a cool Flower of Life image in a preview, the settings can be saved to a preset.
File comment: some random image output with a few tweaks
File comment: The default button is replaced by the preset option.
The plugin was developed on Gimp 3.0.0 RC1.
File comment: Improve previous version.
Flower of Life 2.11.zip [55.96 KiB]
Downloaded 160 times
Charles
PostPosted: Fri Dec 20, 2024 8:26 pm  (#8)
Awesome! Thanks for the early Christmas present gasMask. :)
PostPosted: Fri Dec 20, 2024 11:44 pm  (#9)
Thank you gasmask
Original
Bumped
PostPosted: Sat Aug 23, 2025 12:36 am  (#10)
Did a couple more of these today. The silver one was meant to be the height map but it got bumped instead
PostPosted: Wed Oct 01, 2025 3:42 am  (#11)
Hi gang,
I made a few improvements to this plug-in, and you're welcome to it.
This is the update log entry:
v2.2 Release Date: October 1, 2025
• Switched the window-type from a dialog to a top-most window in order to accommodate Gimp's color button.
• Changed the color buttons to the Gimp user-interface version.
• Improved 'Flower Type/Outline'.
File comment: A random image made with v2.2.1
Edit: The 2.2 version had a bug in the closing code which is fixed here in 2.2.1.
File comment: Fix the previous version.
Flower of Life 2.2.1.zip [59.67 KiB]
Downloaded 98 times
Charles
