It is currently Fri Nov 13, 2026 7:58 pm
 Post subject: Skew All, a Gimp 3 Plug-in
PostPosted: Sat Dec 28, 2024 1:11 am  (#1)
Howdy partner,
I made this plug-in because I thought of the Yin-Yang circle would look interesting if it was transformed into something like a planetary ring.
What the plug-in does is transform every layer in an input image into a skewed rectangle form which is then stacked in a new output image. The resulting layer rectangle is symmetrical but can become many shapes depending on the layer relative skew points.
File comment: a workflow diagram
File comment: This is it.
File comment: You're welcome.
Skew All 1.01.zip [47.31 KiB]
Downloaded 183 times
Charles
 Post subject: Re: Skew All, a Gimp 3 Plug-in
PostPosted: Sat Dec 28, 2024 1:15 am  (#2)
Here's another example.
Charles
PostPosted: Sun Dec 29, 2024 1:47 am  (#3)
Oh how nifty is this! :)
PostPosted: Sun Dec 29, 2024 6:13 am  (#4)
Works great in Gimp 3 RC2.
