It is currently Mon Nov 23, 2026 11:46 pm
 Post subject: Beautify Plug-ins for GIMP 3.0 RC2(include simple-border)
PostPosted: Thu Jan 30, 2025 11:25 pm  (#1)
Windows binary package, because the bug, so not include simple-border
And one more thing
old gimp_curves_spline and new gimp_drawable_curves_spline
same control points but not the same result
Beautify3.0.zip
gimp_drawable_curves_spline uses GMIC Curves instead, The result is similar to version 2.10
beautify_beautify(use GMIC Curves).zip
Source
beautify-master.zip
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
 Post subject: Re: Beautify Plug-ins for GIMP 3.0 RC2
PostPosted: Sat Feb 01, 2025 2:01 pm  (#2)
Looks good on Linux -- (k)Ubuntu Noble 24.04
GIMP 3.0.0-RC2 & dev packages installed from Mateusz Łukasik's mati75 gimp 3.0 PPA
Just had to modify the Makefile:
LIBS = $(GIMP_LIBS) -lm -mwindows
# LIBS = $(GIMP_LIBS) -lm
To:
# LIBS = $(GIMP_LIBS) -lm -mwindows
Build:
$ make
Launch:
$ gimp --verbose
Querying plug-in: '/home/USER/.config/GIMP/3.0/plug-ins/beautify_texture-border/beautify_texture-border'
Querying plug-in: '/home/USER/.config/GIMP/3.0/plug-ins/beautify_skin-whitening/beautify_skin-whitening'
Querying plug-in: '/home/USER/.config/GIMP/3.0/plug-ins/beautify_simple-border/beautify_simple-border'
Querying plug-in: '/home/USER/.config/GIMP/3.0/plug-ins/beautify_rip-border/beautify_rip-border'
Querying plug-in: '/home/USER/.config/GIMP/3.0/plug-ins/beautify_beautify/beautify_beautify'
PostPosted: Sat Feb 01, 2025 2:04 pm  (#3)
I suppose this is the bug with simple-border that you were referring to. Hopefully it can be fixed.
PostPosted: Sat Feb 01, 2025 3:41 pm  (#4)
Hi mojo_lo,
may I ask you to upload your linux compiled files here?
Would be really great.
PostPosted: Sat Feb 01, 2025 7:13 pm  (#5)
Sure, the file's too large to upload directly to gimpchat and I can't post direct links as a new user, so just replace the two <dot>'s in the link below with .
1. Extract the contents of the .gz archive into your /home/<USER>/.config/GIMP/3.0/plug-ins/ folder (each binary should be in its own folder).
There are 5 binaries:
beautify_beautify
beautify_rip-border
WARNING: the beautify_simple-border plug-in is just for reference. It doesn't work as discussed above.
DOWNLOAD LINK
https://www<dot>dropbox<dot>com/scl/fi/pkaccca6twh1elu39xgyt/beautify-gimp300RC2-ubuntu_noble_24.04.tar.gz?rlkey=i1iri8gloz8sk8zta7t92w2w4&st=gl30xdfw&dl=0
2. Get the extra rip-border and texture-border textures from JamesH's beautify-master.zip above. They are in the beautify-master/textures/ folder.
Place them in your /home/<USER>/.config/GIMP/3.0/ folder
Your final directory structure should look like this:
├── plug-ins
│   ├── beautify_beautify
│   │   └── beautify_beautify
│   ├── beautify_rip-border
│   │   └── beautify_rip-border
│   ├── beautify_simple-border
│   │   └── beautify_simple-border
│   ├── beautify_skin-whitening
│   │   └── beautify_skin-whitening
│   ├── beautify_texture-border
│   │   └── beautify_texture-border
├── rip-border
│   ├── art
│   ├── border
│   ├── flowers
│   ├── lights
│   ├── others
│   └── stars
├── texture-border
│   ├── art
│   ├── cloth
│   ├── grid
│   ├── other
│   ├── paper
│   ├── texture
│   └── wall
PostPosted: Sun Feb 02, 2025 3:15 am  (#6)
Thank you!
PostPosted: Wed Feb 19, 2025 12:20 am  (#7)
simple-border already include
 Post subject: Re: Beautify Plug-ins for GIMP 3.0 RC2(include simple-border)
PostPosted: Wed Feb 19, 2025 3:29 am  (#8)
Did you manage to get simpleborder fixed?
PostPosted: Thu Feb 20, 2025 2:21 am  (#9)
Seems to be working fine in Gimp-3.0-RC3 +GIT
PostPosted: Thu Feb 20, 2025 5:38 am  (#10)
It's still broken for me :-(
(Linux Mint 20.2 MATE, GIMP 3.0.0-RC3+git, git-describe: 626af99)
PostPosted: Thu Feb 20, 2025 7:12 am  (#11)
:keybdtype
PostPosted: Thu Mar 20, 2025 7:34 pm  (#12)
On a Windows system, where does Beautify3.0 go? I ask because when I look at where GIMP 3.0 is installed on my Windows 10 system, I do not see this: home/<USER>/.config/GIMP/3.0/ folder .
PostPosted: Sun Mar 23, 2025 1:52 am  (#13)
C:\Users\<USER>\AppData\Roaming\GIMP\3.0\plug-ins
PostPosted: Sun Mar 23, 2025 11:44 am  (#14)
Thank you, JamesH. Is that folder also the same folder that there beautify_beautify folder goes?
PostPosted: Sun Mar 23, 2025 3:04 pm  (#15)
I installed Beautify3.0 on GIMP 3.0, here: C:\Users\<USER>\AppData\Roaming\GIMP\3.0\plug-ins
I open GIMP up and I do not see it under the filters tab. What am I doing wrong? Is there something that I am missing in order for Beautify 3.0 to appear in my Windows system when I load gimp 3.0? GIMP 3.0 also picked up and loaded G'MIC, and Resynthesizer just fine. I'd like some help with this please. Also when GIMP 3.0 loads it picks up a file known as Babl Fishes. Can someone explain that?
This is what the placement of Beautify3.0 looks like in my Windows 10 system:
This is what I see when GIMP 3.0 is up and running on my system:
Thanks,
Mackenzie
PostPosted: Sun Mar 23, 2025 8:40 pm  (#16)
Thanks,
Mackenzie
Sorry, My bad, I forgot there is other folders in zip file
It should unzip to the C:\Users\<User>\AppData\Roaming\GIMP\3.0 folder
PostPosted: Sun Mar 23, 2025 8:52 pm  (#17)
Thanks,
Mackenzie
That's okay. I finally figured it out. On the Windows 10/11 systems Beautify 3.0 goes here:C:\Users\<User>\AppData\Roaming\GIMP\3.0 folder/plug-ins
All of them go there including rip and texture borders.
PostPosted: Sun Jan 04, 2026 2:48 pm  (#18)
Hi
I am having the same problem installing this plug-in on Windows 11 as Mackenzie was on Windows 10. After saving the folders and files downloaded at the location "C:\Users\<USER>\AppData\Roaming\GIMP\3.0\plug-ins\Beautify3.0" no Beatify plug-in appears as an available filter. The G'Mic filter does appear. The folders with binary files being saved in folders with the same name being:
beautify_beautify
beautify_rip-border
Is anyone any to help.
Thanks
PostPosted: Thu Jan 15, 2026 7:45 pm  (#19)
GOGGS wrote:
Hi
beautify_beautify
beautify_rip-border
Thanks
Hi,
Here's where they go: On the Windows 10/11 systems Beautify 3.0 goes here:C:\Users\<User>\AppData\Roaming\GIMP\3.0 folder/plug-ins
It should work once you place the folders into the plug-ins folder and then start up gimp, or restart it. I hope this helps. :)
