It is currently Wed Sep 30, 2026 6:47 am
 Post subject: Plugin Nik Collection based on ShellOut for Gimp 3
PostPosted: Tue Mar 25, 2025 9:34 pm  (#1)
On gimp-forum.net:
https://www.gimp-forum.net/Thread-Conve ... 2#pid43522
user iiey has provided a link to a nikplugin.py plugin for GIMP 3 for image processing with external Nik Collection programs:
https://github.com/iiey/nikGimp
In menu:
Filters ➤ NikCollection
nikplugin.zip [3.7 KiB]
Downloaded 317 times
 Post subject: Re: Plugin Nik Collection based on ShellOut for Gimp 3
PostPosted: Wed Mar 26, 2025 5:14 am  (#2)
Thank you MareroQ for sharing this. :)
PostPosted: Wed Mar 26, 2025 6:58 am  (#3)
Thanks to iiey we now have an easy way to create image processing plugins using other external programs.
PostPosted: Sat Mar 29, 2025 1:17 pm  (#4)
On 27/03/2025, iiey released a new version that displays a message on how to deal with the error reported by Zbyma72age in the HDR Efex Pro 2.exe file.
PostPosted: Thu Apr 03, 2025 12:08 pm  (#5)
iiey released version 3.0.5 which fixed the HDR Efex Pro 2 issue. You should check in Settings though if the output format is set to jpg (because mine defaulted to tiff - and then it doesn't work).
New page:
https://iiey.github.io/nikgimp/
However, the plug-in does not work as described by Zbyma72age (because for it to work properly you need to open several photos from the HDR Efex Pro 2 menu).
what opens the window:
PostPosted: Thu Apr 03, 2025 8:30 pm  (#6)
Some work very fast.
In ver.3.1.0 iiey solved the problem of loading multiple selected layers
PostPosted: Sun Apr 27, 2025 2:49 am  (#7)
Can't get the Nik collection for gimp 3 to show in my gimp. I have it in 2.10.38 and need it in 3 before I bite the bullet and change over from 2.10 to 3 completely.
I have the new updated py plugin for gimp 3 and have put it in the Plugin-ins in two folders as the plugin suggests.
Google>Nik Collection>py plugin
I restarted my computer then gimp and it still doesn't show - as greyed out even
PostPosted: Sun Apr 27, 2025 5:23 am  (#8)
If you are very patient, we will handle this problem. :yes
1. Remove your version of nikplugin and install from the attachment (ver.3.1.0).
2. If it is still not registered in the menu, show a screenshot of the plugin location (so that the full path from C:\ to ....nikplugin\nikplugin.py is visible).
Edit:
Probably better - you wrote directly to the plugin author on gimp-forum.net. (I noticed your new post there). I won't interfere anymore (but you've stirred things up a bit).
nikplugin ver.3.1.0.zip [5.52 KiB]
Downloaded 162 times
PostPosted: Sun Apr 27, 2025 2:13 pm  (#9)
When i installed it i had to remove the word Google from the directory the py plugin looks for the installed program Nik Collection because mine was installed in c:/Program Files/Nik Collection not
c:/Program Files/Google/Nik Collection.
Maybe check for that first.
PostPosted: Mon Apr 28, 2025 12:35 am  (#10)
Edit:
Finally! :yes I downloaded the file you attached and I have finally got it on my computer in Gimp 3.
Thankyou :tyspin :tyspin :tyspin
