It is currently Sat Nov 07, 2026 9:31 pm
 Post subject: Plugin Gimp-3 based on ShellOut for Gimp 2
PostPosted: Mon Mar 31, 2025 11:26 pm  (#1)
This plugin opens Gimp 2 layers in Gimp 3.
Since there is a discrepancy in xcf versions and Gimp 2 will not open xcf file (ver.22) from Gimp 3 this plugin uses TIFF format (which handles layers well).
In menu: File ➤ Export to Gimp 3 (new-instance)
This is what the file opened in Notepad2 (attached) looks like New-instance-Gimp.bat.
In Gimp 3, select layers to edit
Before exporting back, set the Encoding:
Edit Layers and Overwrite:
Now you have two options:
1. Just go back with modified layers to Gimp 2 (without preserving layer mode and NDE editing):
2. Also save as xcf for further editing only in Gimp 3:
Export_to_Gimp.zip [304.57 KiB]
Downloaded 142 times
 Post subject: Re: Plugin Gimp-3 based on ShellOut for Gimp 2
PostPosted: Sun Apr 06, 2025 3:55 am  (#2)
That is very clever but also very Windows ;)
Thinking about it for linux users, linux had workspaces (desktops) long before Windows and you can drag-n-drop between.
Gimp 2.10 on one desktop, Gimp 3.0 on another desktop. Dragging a tab or a layer from one opens in the other. Then it depends where you drop. In the canvas as a new layer or into the tools for a new image.
A little example: You will have to accept that I drag into the other workspace.
https://imgur.com/2NM96ey.mp4 Of course there are limitations, only one layer at a time, such is life.
edit: Missed the important bit, you do have to start one or the other with the new instance -n switch. Just for info that is kubuntu 24.04 and both are appimages.
