It is currently Sat Nov 07, 2026 7:33 pm
 Post subject: Inkscape plugin for Gimp 3
PostPosted: Wed Apr 09, 2025 12:52 am  (#1)
If you don't have Inkscape version 1.4, it's time to install it:
https://inkscape.org/release/inkscape-1 ... directed=1
Run msi installer: inkscape-1.4_2024-10-11_86a8ad7-x64.msi
Select the default installation path c:\Program Files\Inkscape\
Download and unzip Inkscape-plugin.zip (in ... 'HomeDirectory'\plug-ins\Inkscape-plugin\Inkscape-plugin.py)
Uruchom Gimp 3.
In menu: Filters ➤ ShelOut ➤ Inkscape...
Select options in the plugin and run it
If you want to create svg file use Trace Bitmap:
and you can use some Filter:
Save As ➤ Replace 'Name temp-file'.svg
Close Inkscape and you will be back to Gimp with the result
If you want open svg as path:
... and play with the path as you like...
Inkscape_plugin.zip [3.33 KiB]
Downloaded 210 times
 Post subject: Re: Inkscape plugin for Gimp 3
PostPosted: Tue Apr 29, 2025 6:42 am  (#2)
Ver.0.2.
Just a small addition (allows you to create paths in the active image).
Inkscape_plugin Ver.0.2.zip [3.68 KiB]
Downloaded 191 times
PostPosted: Tue Apr 29, 2025 6:55 am  (#3)
Great idea MareroQ! Hey for the life of me i cannot get Inkscape 1.5 dev to work in Windows 10. I get an open container for the splash and the opened program window. I have GTK 4 installed in c:/GTK 4 and the environment variables set correctly, but i still cannot get it to work. I was wondering if you could check it out. Maybe you can figure it out. :)
Thx for the new plugin for Inkscape in Gimp-3.
PostPosted: Tue Apr 29, 2025 7:42 am  (#4)
Sorry Rod but after Your experience I will not experiment with the development version and will stick with stable 1.4.
PostPosted: Tue Apr 29, 2025 8:17 am  (#5)
No reason to be sorry. :bigthup Just wondering if you knew how to fix it. It is a conumdrum for me. :puzzled
PostPosted: Thu Jun 19, 2025 10:06 am  (#6)
I have Inkscape 1.5 DEV working in Windows 11. :)
viewtopic.php?f=26&t=21319
PostPosted: Mon Aug 25, 2025 5:52 am  (#7)
Hi MaroreQ, just a typo fix on line 301.
procedure.add_menu_path("<Image>/Filters/ShellOut")
Thanks much for all the Gimp 3 updates :tyspin
