It is currently Sat Nov 07, 2026 9:31 pm
 Post subject: Gimp 3.0 plug-ins in a separate group
PostPosted: Mon Apr 21, 2025 5:43 am  (#1)
Maybe it is an idea to put plugins for Gimp 3.0 in a separate group. I mean here on this site.Because I always have to search
 Post subject: Re: Gimp 3.0 plug-ins in a separate group
PostPosted: Mon Apr 21, 2025 6:33 am  (#2)
Jappaloe63 wrote:
Is it perhaps an idea to place plug-ins for 3.0 in a separate group.
Why not ? Anything to make things easier. When Gimp 2.10 moved the User profile I started using a separate folder for resources - not just plug-ins, but scripts , fonts , patterns .... Plugins like gmic which come with a Windows installer, let them use the default but if you have to install manually, easier if you do not need that appdata/roaming nonsense.
What you do not want to do, as is sometimes seen here, is a separate path for each-and-every plugin
A bit easier with linux than Windows, for example this for my Gimp 3.0 plug-ins
PostPosted: Tue Apr 22, 2025 1:18 am  (#3)
I was going to suggest the same. Perhaps a new board under gimp scripts and plugins?
For instance - Gimp-3.0 resources?
PostPosted: Sun Jun 22, 2025 10:38 pm  (#4)
Most of my plugins work on GIMP 2.10 and GIMP 3, so what am I suppose to do?
And infact virtually all of my plugins would work on 2.10 if one manually compiles `gegl:bevel` and `gegl:inner-glow` that GEGL 0.4.50 has. I might as well put them in the GIMP 3 category because I want people to use GIMP 3 anyway for a better experience with my plugins.
PostPosted: Mon Jun 23, 2025 1:59 am  (#5)
I would say just keep placing them into the thread you have going Beaver. ;)
And as you have in the past warn if they will not work in Gimp-2.10 versions.
That would be fine.
PostPosted: Mon Jun 23, 2025 2:25 am  (#6)
I guess I don't understand what's going on.
In Gimp 2.10.38 Win10 64bit Bevel and Inner-Glow seem to work fine.
By the way, have you tried it?
viewtopic.php?f=7&t=20657&p=297046#p296948
PostPosted: Mon Jun 23, 2025 3:04 am  (#7)
I'm not talking about those. Of course they work fine
I'm talking about the official bevel and inner glow that ship with GIMP 3. They do not use `lb:` they use `gegl:`
Personally, I prefer lb:innerglow over `gegl:inner-glow` as it does more and doesn't have the "clip at the legs issue". However, I usually use gegl:bevel over the `lb:bevel, lb:custom-bevel, lb:sharp-bevel` filters just because it does all three in one and it has a better faster chamfer bevel algorithm then lb:sharp-bevel.
Still GEGL Effects depends on `lb:bevel` and `lb:innerglow` and will never depend on the official bevel and inner glow.
Regarding Grok,
No, I have not prompted Grok on Math map and after using him for a month he is actually quite limited only knowing how to draw shapes, gradients, patterns, distortion maps and lighting filters. Regarding GEGL plugins Grok fails 90% of the time and its a slow process of weeding out his mistakes and locking him into parameters that work.
PostPosted: Mon Jun 23, 2025 3:18 am  (#8)
Regarding Grok,
WELL said! :hi5
PostPosted: Mon Jun 23, 2025 10:15 pm  (#9)
Regarding Grok,
WELL said! :hi5
For now on I will call those plugins "Official GEGL Bevel" and "Official GEGL Inner Glow" to distinguish them
PostPosted: Tue Jun 24, 2025 7:21 am  (#10)
Compiled for Gimp 2.10:
viewtopic.php?f=9&t=21761
