It is currently Fri Nov 13, 2026 6:21 am
 Post subject: Voronoi Stippler for Gimp3 Win10
PostPosted: Mon Apr 21, 2025 11:29 am  (#1)
Create new layers and/or path for tracing png to SVG using VORONOI STIPLER.
Stippling is the creation of a pattern simulating shading by using small dots.
Voronoi: http://web.archive.org/web/201612011249 ... tions.html
Unzip the attachment and place it in your (home) plug-ins directory.
It also contains the necessary exe and dll libraries.
Very important:
The plugin path cannot contain directories with spaces and special (accented) characters.
The default installation and portable version of Samj meet these conditions.
This plug-ins:
1.Saves active layer as File-name.bmp in dir Voronoi_for_Gimp3.
2. Launches Voronoi.exe (console) - create 'File-name'.svg.
3. Wait for the console to close.
* Need to increase 'Waiting Time' - when window 'Render Scalable Vector Graphics' opens before closing console!
4. Opened 'File-name'.svg as layer and/or path.
IF YOU DO NOT RENAME THE FILE, THEY WILL BE OVERWRITTEN.
In menu: Filters ➤ Edge-Detect ➤ Voronoi Stippler
Edit 25.04.2025
Changed attachment:
disabled 2 lines from sys.stderr (which are only intended for diagnosing possible problems in the code)
For some users this was the reason for no registration in the menu.
Voronoi_Stippler_for_Gimp3.zip [290.55 KiB]
Downloaded 1772 times
DocVoronoi.zip [1.37 MiB]
Downloaded 1900 times
