It is currently Sat Nov 07, 2026 9:31 pm
 Post subject: Potrace for Gimp3 Win10
PostPosted: Mon Apr 21, 2025 11:33 am  (#1)
Potrace(TM) is a tool for tracing a bitmap, which means, transforming a bitmap into a smooth, scalable image.
Potrace-1.16:
https://potrace.sourceforge.net/#description
https://potrace.sourceforge.net/#downloading
Unzip the attachment and place it in your (home) plug-ins directory.
It also contains the necessary exe and dll libraries.
Very important:
The plugin path cannot contain directories with spaces and special (accented) characters.
The default installation and portable version of Samj meet these conditions.
This plug-ins:
1.Saves active layer as File-name.png in dir Potrace_for_Gimp3.
2. Launches potrace.exe (console) - create 'File-name'.svg.
3. Wait for the console to close.
4. Opened 'File-name'.svg as layer and/or path.
IF YOU DO NOT RENAME THE FILE, THEY WILL BE OVERWRITTEN.
In menu: In menu: Filters ➤ Edge-Detect ➤ Potrace
Stroke path manualy:
Potrace_for_Gimp3.zip [152.63 KiB]
Downloaded 9179 times
 Post subject: Re: Potrace for Gimp3 Win10
PostPosted: Thu Apr 24, 2025 2:54 am  (#2)
I just deleted 2 lines in the plugin and Potrace now visible in gimp 3 and working (see image for deleted lines). I don't know if the plugin need this two lines. I get no error.
PostPosted: Thu Apr 24, 2025 3:15 am  (#3)
Hi Denzjos.
This is a very interesting solution to the problem.
You are right that these two lines are not needed for the plugin to work (but they are useful when writing because they allow you to analyze possible problems).
It is just a mystery to me why the plugin registers correctly in my Gimp without removing these two lines.
PostPosted: Thu Apr 24, 2025 11:04 pm  (#4)
If any of the users had a situation (problem and solution) identical to Denzjos, please let me know.
Attached is a file without 2 lines (diagnostic).
Potrace_for_Gimp3.zip [152.6 KiB]
Downloaded 134 times
PostPosted: Mon Apr 28, 2025 3:30 am  (#5)
Potrace.exe, Autotrace.exe, and voronoi.exe don't show up in the navigation menu under edge detect in GIMP 3.0, for me. I'm also having trouble with FilterForge. I can't get the .py file to show up in GIMP 3.0. If anyone can help me figure out how to get these plugins to work and show up in GIMP, I'd appreciate it.
PostPosted: Mon Apr 28, 2025 3:50 am  (#6)
Potrace and Autotrace are working fine for me.
PostPosted: Mon Apr 28, 2025 4:04 am  (#7)
1 You have to have Filter Forge installed.
2 You have to give permissions (full) for the tga lifesaver file in Program Files/Filter Forge (your version #)/Previews/StandardImageOpaque1Lifesaver.tga
Right click the tga file and select properties/security and give full perms to the user listing.
PostPosted: Mon Apr 28, 2025 5:38 am  (#8)
Hi mackenzieh.
Make sure you have the latest version.
In this case it's not the exe files that register in the menu but the py files.
In Gimp 2.10 the exe and dll files went to the bin directory in Gimp but I found a way to change that (now they are all in one subdirectory - which is important when changing the Gimp version or uninstalling it).
Did you keep the file hierarchy?
Gimp 3.0 plugins are now required to be in a separate subdirectory.
PostPosted: Mon Apr 28, 2025 2:30 pm  (#9)
Thanks Rod. I've decided not to install filterforge.
PostPosted: Mon Apr 28, 2025 2:38 pm  (#10)
MareroQ wrote:
Hi mackenzieh.
Hi MareroQ,
I have the latest version of GIMP 3.0 and the plugins.
Here's where I placed the plugins:
When gimp 3.0 loads, I don't see the plugins in their designated categories.
PostPosted: Mon Apr 28, 2025 3:30 pm  (#11)
For diagnosis I need screenshots with paths to files (not directories):
Autotrace_for_Gimp3.py
Potrace_for_Gimp3.py
Voronoi_Stippler_for_Gimp3.py
On the sidelines: there is one error with resynthesizer.exe - it is not in a subdirectory resynthesizer.
PostPosted: Tue Apr 29, 2025 12:36 am  (#12)
Could this possibly be the problem?
viewtopic.php?f=9&t=21641&sid=be77511ce7d0236eb4d923e3d022c6b3#p296022
PostPosted: Tue Apr 29, 2025 6:45 pm  (#13)
MareroQ,
This is what I see where I put the files:
As for Resynthesizer.exe, the subdirectory didn't catch on, so I just put the file there instead and when GIMP 3.0 loaded, so did the plugin.
EDIT: Two plugins show up in GIMP 3.0: Potrace & Autotrace. Voronoi Stippler does not show up in GIMP 3.0 under edge detect.
PostPosted: Tue Apr 29, 2025 11:15 pm  (#14)
edit due to additional information in the post #13
Everything looks fine (except for the older version of Voronoi)
viewtopic.php?f=9&t=21640
and I don't know why these plugins don't register in the Gimp menu.
If nikplugin registers in the menu (let me know if it does), then that also rules out a general Python problem (and Python Console registers in Filters/Development/Python-Fu) and I don't know how to fix it.
Can You check if starting Gimp by directly clicking gimp.exe (in ?: Program Files/Gimp 3/bin) makes any difference?
That's all I can do to solve this problem at the moment. :oops:
Back to the resynthesizer:
I placed it like you did, without a subdirectory, Gimp loaded without any error messages, but try running Heal Selection for example and you'll get an error:
PostPosted: Wed Apr 30, 2025 7:38 pm  (#15)
I doubt that Voronoi is an older version because I downloaded the zip file Voronoi_Stippler_for_Gimp3.zip which you provided. I think the only file needed for Voronoi_Stippler_for_Gimp3 is the .py file. I haven't tried the resynthesizer yet, but I will. Voronoi Stippler still doesn't load in GIMP 3.0 under edge-detect.
PostPosted: Wed Apr 30, 2025 9:28 pm  (#16)
Sometimes I guess intuitively, but not this time.
You have the version from 21.04.2025 - you need the one from 25.04.2025
PostPosted: Thu May 01, 2025 7:54 pm  (#17)
Where can I download the current version?
PostPosted: Thu May 01, 2025 9:19 pm  (#18)
I provided the link in post no. #14 (and when you read it, it says when and why the attachment was changed).
PostPosted: Thu May 01, 2025 10:35 pm  (#19)
I downloaded it again. I'm starting GIMP 3.0 up now. Voronoi Stippler is there under edge detect. :)
PostPosted: Thu May 01, 2025 10:53 pm  (#20)
... and just a suggestion:
the right question in the right thread :roll: :)
