It is currently Wed Nov 11, 2026 6:59 pm
 Post subject: Copy multiple times for Gimp 3
PostPosted: Fri May 02, 2025 1:55 pm  (#1)
A simple plugin but can save you some time.
Copies the active layer a specified number of times.
In menu: Layers ➤ Copy multiple times
(You need to click on the layer in the Layers dock).
Copy_n_times_for_Gimp3.zip [2.06 KiB]
Downloaded 130 times
 Post subject: Re: Copy multiple times for Gimp 3
PostPosted: Fri May 02, 2025 3:33 pm  (#2)
Excellent idea. I wonder if this plugin
viewtopic.php?f=9&t=9446&hilit=multiple+layer+actions
Could be re edited to work in Gimp-3?
PostPosted: Fri May 02, 2025 6:13 pm  (#3)
80% of the functionality is native already since you can select multiple layers in Gimp3
PostPosted: Sat May 03, 2025 6:44 am  (#4)
The transition from Gimp-2.10 "habits" to Gimp 3 is slow, and this plugin doesn't work for multiple selections (it will use the first layer in the list). :(
PostPosted: Sat May 03, 2025 7:46 pm  (#5)
That's too bad. :roll:
