It is currently Thu Nov 12, 2026 6:21 pm
 Post subject: Example of using the G'MIC filter in the py plugin for Gimp3.
PostPosted: Mon May 05, 2025 8:07 am  (#1)
For some reason unknown to me (since I don't know Python3 or the Gimp3 API :oops: ), a respected forum user asked me for an example of a py plugin using G'MIC.
It's nothing interesting except for a simple example.
In menu: Test ➤ Average py
Edited to include a screenshot from G'MIC
Gmic_average.zip [2.12 KiB]
Downloaded 2631 times
 Post subject: Re: Example of using the G'MIC filter in the py plugin for Gimp3.
PostPosted: Mon May 05, 2025 8:30 am  (#2)
That is a good example, thank you very much. Works fine with my linux Gimp 3.0.2 appimage.
At the same time I find it very depressing that Gimp python 3 is so verbose and (for me) complicated.
PostPosted: Mon May 05, 2025 8:54 am  (#3)
Hi Rich.
My opinion is the same. :gaah
And it was supposed to be easier and faster, which I've read many times (it may be so for professional programmers).
I wrote plugins for Gimp2 for my own pleasure, and for Gimp3 I just check if I can still think logically. :mrgreen:
PostPosted: Tue May 06, 2025 3:12 am  (#4)
Thanks for sharing this! Even if it’s a simple example, it’s still really helpful for those of us trying to understand how G’MIC can be used inside a py plugin. Sometimes small, clear examples are the best way to get started. Appreciate the effort!
Hi there! I'm Zu. It's a pleasure to meet you. I'm excited to connect and get to know each other better. Let's have a great conversation and share wonderful experiences together!
PostPosted: Tue May 06, 2025 12:54 pm  (#5)
Also this topic on gnome's discourse might help:
https://discourse.gnome.org/t/porting-a ... imp3/28081
PostPosted: Wed May 07, 2025 3:13 am  (#6)
Thank You very much for the link provided.
I consider the Nelo widget_variants.py plugin to be the most useful help.
PostPosted: Fri May 16, 2025 10:15 am  (#7)
A bit more extensive usage example: G'MIC and GEGL
- using GEGL based on Choice-demo.py by Ofnuts,
- new widgets based on widget_variants.py by Nelo.
In menu: Test ➤ GMIC Stringify and GEGL Emboss
GMIC Stringify:
GEGL Emboss:
Gmic_stringify_and_Gegl_Emboss.py:
Background Color is HTML Notation:
Example 1:
Example 2:
Gmic_stringify_and_Gegl_Emboss.zip [3.56 KiB]
Downloaded 629 times
PostPosted: Sun May 18, 2025 5:08 am  (#8)
Ver.0.1 Gmic_stringify_and_Gegl_Emboss:
- GEGL based on foggify.py by James Henstridge,
- tested radio_frame and a comment inside the dialog box.
Gmic_stringify_and_Gegl_Emboss Ver.0.1.zip [3.56 KiB]
Downloaded 3268 times
PostPosted: Fri May 23, 2025 10:48 am  (#9)
I have slightly updated widget_variantions.py by Nelo.
However, there are still no equivalents from Gimp2: PF_VECTORS, PF_TEXT.
In menu: Test ➤ Show Widget Options
This code fragment is responsible for displaying widgets:
You will only need some of them for your plugin, so you can disable unnecessary ones
# -> comment on widgets you won't use
Show_Widget_Options.zip [3.57 KiB]
Downloaded 611 times
PostPosted: Fri May 23, 2025 2:50 pm  (#10)
:tyspin
